- Joined
- Aug 9, 2006
- Messages
- 389
- Points
- 1,516
DVC Subwoofer 100% Made in USA
100% Made in USA sub-woofer by Eminence
- Direct from Eminence Factory in US!
- Dual Voice Coil 8//8= 4 Ohm
- Polypropylene Cone with Inverted Dust Cap
- Santoprene Rubber Surround
- Extended & Vented Pole Piece
- Bumped Magnet Back Plate
- Copper Voice Coil with Polymide former
- Classic Standard American Basket & Terminal
- Outstanding Bass performance in small sealed box for real Deep Bass!
- Usefully Low Fs & Good power handling & 8mm Xmax
- Application for a Car ,Home theater or Professional Sound Reinforcement
- Specification similar to Madisound-Eclipse woofer: Eclipse Woofers by Eminence from Madisound
- Very Good for SQ set-up in Car
Available: 10" & 12"
12" Spec.:
* Fs 21.48
* Impedance 4 ohm #
* Bl 15.38 Tm
* Qms 6.599
* Qes 0.262
* Qts 0.252
* Xmax 8.0mm
* SD 0.0533 m2
* Surround rubber
* Magnet 60 oz.
* Voice Coil 2"
* Power Handling 200 watts RMS/400 watts max
* Freq. Response 25-1000Hz
* Efficiency [email protected]
PRICE: RM380 per piece
10" Spec.:
* Fs 18.36
* Impedance 4 ohm #
* Bl 9.95 Tm
* Qms 4.694
* Qes 0.341
* Qts 0.318
* Xmax 8.0mm
* SD 0.0354 m2
* Surround rubber
* Magnet 40 oz.
* Voice Coil 2 in.
* Power Handling 150 watts RMS/300 watts max
* Freq. Response 28-1500Hz
PRICE: RM320 per piece
# Note: All specifications are with voice coils connected in parallel.
Interested,
pls PM or contact me at
012-9142998 (Lim)
bulks order are welcome.
About Eminence:
The World's Best leading manufacturer of loudspeakers since 1960.
If you you've heard live music, chances are you've heard Eminence quality.
Made in the USA by Eminence:
The first Eminence facility, located in downtown Eminence, employed around thirty people. The building was less than 6,000 sq. ft. and production was often less in one week than it is in one hour at our present facility. In 1972 Eminence Speaker moved to a new location in Shawnee Industrial Park on Mulberry Pike where we remain today. The facility has seen several additions. The first building in this location was just less than 30,000 sq. ft., but now has grown to include nearly 100,000 sq. ft. all under one roof.
Warranty
All genuine Eminence loudspeakers are supported by a 7-year warranty against any manufacturer's defect in the continental United States.
OEM:
The Eminence roots are in custom manufacturing. The design and manufacture of special models for a whole range of leading music equipment companies is still the bulk of Eminence business. Eminence has produced thousands of confidential manufacturer-specific formulas since 1966.
Reason to trust:
OEM to Marshall, Fender, Gibson, and all leading musical instrument & professional sound reinforcement.
>>>Do you know, all Marshall/ Fender's guitar amplifier are using Eminance speakers./www.icehifi.com/Smileys/default/64.gif
Sample of Fender speaker below: "manufacture by Eminence Speaker Corporation in Kentucky(USA).
12" Spec.:
* Fs 21.48
* Impedance 4 ohm #
* Bl 15.38 Tm
* Qms 6.599
* Qes 0.262
* Qts 0.252
* Xmax 8.0mm
* SD 0.0533 m2
* Surround rubber
* Magnet 60 oz.
* Voice Coil 2"
10" Spec.:
* Fs 18.36
* Impedance 4 ohm #
* Bl 9.95 Tm
* Qms 4.694
* Qes 0.341
* Qts 0.318
* Xmax 8.0mm
* SD 0.0354 m2
* Surround rubber
* Magnet 40 oz.
* Voice Coil 2 in.
Interested,
012-9142998 (Lim)
About Eminence:
Warranty
OEM:
Reason to trust:
