wts: DVC 12" & 10" Subwoofer Made in USA by Eminence
ICE -In Car Entertainment
lmh77
DVC Subwoofer 100% Made in USA
100% Made in USA sub-woofer by Eminence
- Direct from Eminence Factory in US!
- Dual Voice Coil 8//8= 4 Ohm
- Polypropylene Cone with Inverted Dust Cap
- Santoprene Rubber Surround
- Extended & Vented Pole Piece
- Bumped Magnet Back Plate
- Copper Voice Coil with Polymide former
- Classic Standard American Basket & Terminal
- Outstanding Bass performance in small sealed box for real Deep Bass!
- Usefully Low Fs & Good power handling & 8mm Xmax
- Application for a Car ,Home theater or Professional Sound Reinforcement
- Specification similar to Madisound-Eclipse woofer: Eclipse Woofers by Eminence from Madisound
- Very Good for SQ set-up in Car
Available: 10" & 12"
12" Spec.:
* Fs 21.48
* Impedance 4 ohm #
* Bl 15.38 Tm
* Qms 6.599
* Qes 0.262
* Qts 0.252
* Xmax 8.0mm
* SD 0.0533 m2
* Surround rubber
* Magnet 60 oz.
* Voice Coil 2"
* Power Handling 200 watts RMS/400 watts max
* Freq. Response 25-1000Hz
* Efficiency [email protected]
PRICE: RM380 per piece
10" Spec.:
* Fs 18.36
* Impedance 4 ohm #
* Bl 9.95 Tm
* Qms 4.694
* Qes 0.341
* Qts 0.318
* Xmax 8.0mm
* SD 0.0354 m2
* Surround rubber
* Magnet 40 oz.
* Voice Coil 2 in.
* Power Handling 150 watts RMS/300 watts max
* Freq. Response 28-1500Hz
PRICE: RM320 per piece
# Note: All specifications are with voice coils connected in parallel.
Interested,
pls PM or contact me at
012-9142998 (Lim)
bulks order are welcome.
About Eminence:
The World's Best leading manufacturer of loudspeakers since 1960.
If you you've heard live music, chances are you've heard Eminence quality.
Made in the USA by Eminence:
The first Eminence facility, located in downtown Eminence, employed around thirty people. The building was less than 6,000 sq. ft. and production was often less in one week than it is in one hour at our present facility. In 1972 Eminence Speaker moved to a new location in Shawnee Industrial Park on Mulberry Pike where we remain today. The facility has seen several additions. The first building in this location was just less than 30,000 sq. ft., but now has grown to include nearly 100,000 sq. ft. all under one roof.
Warranty
All genuine Eminence loudspeakers are supported by a 7-year warranty against any manufacturer's defect in the continental United States.
OEM:
The Eminence roots are in custom manufacturing. The design and manufacture of special models for a whole range of leading music equipment companies is still the bulk of Eminence business. Eminence has produced thousands of confidential manufacturer-specific formulas since 1966.
Reason to trust:
OEM to Marshall, Fender, Gibson, and all leading musical instrument & professional sound reinforcement.
>>>Do you know, all Marshall/ Fender's guitar amplifier are using Eminance speakers./www.icehifi.com/Smileys/default/64.gif
Sample of Fender speaker below: "manufacture by Eminence Speaker Corporation in Kentucky(USA).
appreciate for specifying the models...for research purpose and comparison
Eclipse Comparison Chart
Parameters EMI-1550 W1238R W1038R
Size 15" 12" 10"
in Fs 22.54 21.48 18.36
Impedance 8 6 6
ohm Mms 84.2 86.5 58.4
g Cms 510.0 586.39 1207.4
m/n Vas 501.3 236.5 214.9
l Rscc 6.73 4.9 4.7
ohm Leap Krm 5.637 3.368 3.439
Leap Kxm 15.165 28.125 25.412
Leap Erm 0.750 0.868 0.813
Leap Exm 0.700 0.738 0.670
vcL 4.13 2.84 1.4
mH @1K Bl 19.38 15.38 9.95
Tm Qms 10.00 6.599 4.694
Qes 0.23 0.262 0.341
Qts 0.23 0.252 0.318
Xmax 7.15 8.0 8.0
mm Peak SD 832 0.0533 0.0354
m2 Surround Cloth accordion Rubber Rubber
Magnet 67 40 40
oz. Voice coil 2", 4 layer, Cu 2" 2"
in Power 150 150 100
watts Freq. response 23-1700 25-1000 28-1500
Hz SPL 96.3 92 88
dB @2.83V Flange diameter 389mm, 15.3" 12" 10-1/8"
Mounting hole 356mm, 14" 11" 9-1/8"
Depth 146mm, 5.75" 5-3/8" 4-7/16"
---------- Post added at 08:21 PM ---------- Previous post was at 08:17 PM ----------
12" Model: W1238R
10" Model: W1038R
---------- Post added at 08:28 PM ---------- Previous post was at 08:21 PM ----------
---------- Post added at 08:28 PM ---------- Previous post was at 08:28 PM ----------
thanks for answering... is this woofer good ar? hav u try it before? deep bass? cause i saw that the magnet oz kinda small... tq
Don't worry bro.,
US made woofer quality, anytime much much better than others...
For Best Deep Bass,
10" Sealed Box Enclosed: 0.75~1 cu.ft.
12" Sealed Box Enclosed: 1.25~1.75 cu.ft
*Have you seen Marshall Bass Guitar Amplifier's speakers?? look at behind ...
Some speakers magnet also very small even some are in Alinco magnet, smaller than yr finger thumb!
Accuracy is important.
If don't mind, feel free to contact me at
012-9142998 (Lim)
---------- Post added at 09:29 AM ---------- Previous post was at 09:16 AM ----------
---------- Post added at 09:36 AM ---------- Previous post was at 09:29 AM ----------
If you want Big Magnet, colourfull, stylish & 10000Watts, go to buy China made speakers!
:banghead:
OH... sorry bro for all those question, cause i don really know much bout audio system.. where's ur location? shop? thanks
Hi Bro.,
My location is in USJ,
father's shop in S'ban.
Work as part time.
Can you PM me yr contact no.?
---------- Post added at 11:14 AM ---------- Previous post was at 11:11 AM ----------
Great opportunity to buy a solid, made in the U.S.A., sub for this unbelievable price!
Hi Bro.,
Work as part time.
PMed.
Bro,
Warranty says 7 years but in continent of USA.
In Malaysia how?
If this product is from US, that means QC is more higher than others country.
Do you thing US laws can simply wrote 7 years warranty? :proud:
Don't worry , this woofer are not from Reject or Defective.:listen:
Additional RM35 for sealed box enclosure if you need the woofer box.
