Envy you la GT...got such a deep pocket...
where got....shallow only....
.Envy you la GT...got such a deep pocket...
.there's a lot of choice to choose from.all depends on ur budget bro.u can go from gab s.s seriesHi Bros,
I need to change my suspension for Waja.
Looking to a set of HiLo SoftHard Adjustable, can recommend a reliable one? Not too harsh, but comfortable ride.
Many thanks
koni with eibach spring is a good choice for comfort and spirited driving.alo all bro n sifu...i'm now using stock suspension for my civic eg so i just want to change it...what is the best suspension for my car?performance n comfort?so far i have asked from frend but there to many brand the've said...they also said the wrong choice may co bumpy and uncomfortable for riding especially in malaysia road...really need help...tq very2 much...
thank you GT_AUTO, i have budget around RM2.5k.
What is the price of GAB SS? TEIN? Hotbits? and the like? which is better in terms of ride comfort since this is my daily driver running around car.
Recommend me a brand to start with.
Thanks
Zerone for Mazda 323 familia have or not?
for that budget,u can only opted for gab,d&d,hot bits and d2 bro.tein cost rm3600 per set.
go for gab s.s series.it's only rm2200 per set with 36 click of damping adjustable.or u can
go cheaper with d&d.if i'm not mistaken,the price is only sub rm2k.the cons about d&d is that
it's only 6 or 8 click adjustable damping.i might be wrong on d&d.what car r u using bro?and
with what engine?
depending on budget you might want to go for:
1. an adjustable oem strut like KYB AGX or any non-adj Gas Strut you can find like Excel-G, Paraut, match it up with any name brand lowering spring either from the U.S or Japan
you can also get sleeve type coilovers fitted to the struts, stay away from the china made stuff
2. For Coilovers - if you can get the name brand stuff like tein, progress, JIC then go for it as you can really feel the compression/rebound adjustability on these brands, i suggest getting a softer rate spring in the range of 300/250 inch/lbs or 300/200 inch/lbs.
for the Taiwan/China Made Coilovers - the damping adjustability for compression/rebound is not as noticeable plus the valving is not very specific for each vehicle make and model as settings where based on shock dyno results which they pretty much applied for a number of vehicles (kinda like a one size fits all) plus the Spring Rates are too high resulting in premature wear on the seals. if you do order - just get softer spring rates as valving on most of these brands will probably be only able to handle anywhere from 300 to 400 maximum inch/lbs
Don't get me wrong, its quite alright to use the China/Taiwan Made Coilovers - you just get what you pay for.
3. If you plan on Fabricating your own Coilovers - i suggest doing a lot of Fabrication How-to Research on the web - Use Koni Yellows and Ground Control Sleeve type CO's with a proven Spring rate set that you can live with.
Tevs
A good sets of TEIN cost about 1.8k-2.2k
TEIN are good, the springs and abs are very durable. But comfort is abit harsh, especially when you high speed on highway, when the road is uneven u feel very sudden drops and jolts, but the car sticks on the road like a magnet. You can compensate this problem by using good 55-60series tyres, pumping 28.5psi on the front, and 27psi on the back, to get some comfort. Dont use 50series tyres, coz it will be rock hard.
TIEN HA has 30clicks on the front, 26clicks on the back.
that is for a set of used 1 bro.since his budget is around 2.5k,better opted for a new 1 with
1 year warranty.i've seen a couple of my friends bought used tein for rm1.8k and only
manage to used it for 2 month.the abs leaks oil.
depending on models,tein can be comfortable too.not all of the model r harsh.![]()
Gee, thanks for your enlightenment. I think I got lucky buying a used one, coz I used 1 yr still no leak....hehe....
Btw, servicing a TIEN cost around 400-500. Even if bought one used 1.8k, after servicing ending up 2.3k still a good buy. Coz a new one is damn expensive.....hehe
if i'm not mistaken,the center bearing need to be replace.try those company like gab and hwl.do anyone know where to service HKS pillow ball bearing..my bearing spoiled so very noisy..anyone help??
Need your help for clarifications. Currently i'm using adjustable hotbit for my SV4, and plannng send for service or re-fill back after using many years. But according my foreman, this hotbit cannot re-fill eventho send to speedwork. Because hotbit using gas + fluid.
Is it true? Means i need replace new one?
Thanks in advance for your comment...
just bought tein ha second hand at prs sri kembangan.got 24 click.good PR there..lot of tips from ah sim..really satisfied with tein...rate 12 front 6 rear.. front 8 click n rear 12 click from hard..still best setting for my perdana tt for everyday driving![]()
ya lor bro.depends on model la bro.tein adj price start from rm1.8k and above.the rm1.8k is
for kancil.....![]()
Tires Become Latest Chinese Product to Threaten...
