b16a, b16b - im newbie to hondas!
consonar
D'sara - S.alam
dear guys...
as stated, im very-very and very new to hondas.. and i want to know about hondas more...
ok, straight to the point... i want to know, about the code and the different..
so, throw a few question to you guys... hope guys can help me with my question :
1) b16a and b16b - what the different?
2) got b16c ke?
3) some guys said.. "hey i'm b18b!" OMG.. what is b18b?
4) got b18a ke?
5) is it b18c is Type R?
6) but, when it come to b20, people only stated b20... how bout b20b? b20c? got any arr??
so, as i remind, im very2 newbie to this variant B-series... hope this lame question doesn't give u troublesome... any guys want to reply? pls proceed and i'll thanks those reply in advance!!
maybe hattech-v can reply...
*hattech mesti dah xkenai aku...
Welcome to the world of DOHC VTEC
dear guys...
1) b16a and b16b - what the different? b16a is the first gen DOHC VTEC...comes in small v and big v which are 1st and 2nd gen respectively. b16b us the 2nd gen 1.6 DOHV VTEC which is from the EK Civic Type R
2) got b16c ke? Don't think so.
3) some guys said.. "hey i'm b18b!" OMG.. what is b18b? Maybe referring to the Integra GSR (4round lights) engine but I may be wrong
4) got b18a ke? Don't think so.
5) is it b18c is Type R? Not necessarily...We usually say b18cR if its the Type R one....
6) but, when it come to b20, people only stated b20... how bout b20b? b20c? got any arr?? Reason is because b20 is a hybrid engine....they use the b16a head (usually) and mate it with the b20 block from the CRV. It's not a factory spec engine. The factory spec one is K20 which is the one in the DC5 integra and FD Civic Type R.
perghhhh... im just look into wiki honda B series - Honda B engine - Wikipedia, the free encyclopedia ..
OMG.. im clueless... lol... but neway, maybe we can share some knowledge ..
---------- Post added at 03:45 PM ---------- Previous post was at 03:32 PM ----------
thanks a lot integramania... fuhhh... thanks a lot for those answer... honestly, im very2 new in honda's engine... and i think somehow it is hard coz the honda's breed is very-very byk punya code engine...
one more .. can i do like this?
block B18B + head 16b + camshaft type-R
1. can i do this?
2. pro n con?
3. can all the valve set* spring,camshaft etc etc from type-R to be put in B16B head?
once again, a silly question to all otai!
Bro...it's ok...All of us also learn slowly...
1. can i do this? no probs, Type R cams will really make u feel the power when u swap from the stock ones
2. pro n con? it's a good match...don't think there is a con
3. can all the valve set* spring,camshaft etc etc from type-R to be put in B16B head? Yeap....Best you buy a completeb16b head which has all this inside already since b16b is a Type R. The cam profile is slightly better than the b18cR one
4. For higher compression, you can change the pistons to b16b ones as the dome shape is higher as compared to the b18c one which is flatter. But make sure the mech has done this before. If not it can be dangerous
b18b block is originated from USDM models (US market) where they have DOHC 1.8 Non-vtec.
it is said that the b18b block has most torque therefore alot of US ppl use that block and pair it with a type R head (b16b or b18cR).
just to clarify things to the TS,
B16A - 1.6 DOHC VTEC
B16B - 1.6 DOHC VTEC Type R (red head cover)
B18C - 1.8 DOHC VTEC (also known as B18C GSR - it has an inverted intake manifold)
B18CR - 1.8 DOHC VTEC Type R (red head cover)
Q#1 - yes but most importantly, u should start with a complete halfcut, say maybe a b16b. reason being, u cant just buy it and expect to get everything to get the car going. maybe u could, but do u trust the condition of parts being sold these days? furthermore, u will need 2 very important component... the wiring and the ecu. these 2 are quite hard to come by nowadays, and even if there is... the price will be sky high. what i would suggest is, get a compelte halfcut (b16a/b16b/b18c/b18cR) so u have everything. b16a would be cheapest. then u can re-use the wiring/rechip the ecu, re-use the gearbox etc. pretty much just seek for the b18b block. cams can be sourced later on, however, b16b and b18cR cams differ, just so you know.
Q2 - pro's is, if done correctly, u will probably be running on the highest torque-ed b18 out there. aside from a b20 that is. very powerful low end and also high end. con's - if not done properly, ur car will be in the workshop more than it will be at ur house porch. engine can easily blow, which also means, u will be changing ur engine block very very often...
as for your question #3 -
to interchange parts for the head - almost everything is interchangeable.
as for block - b16a is a class of its own, b16b/b18c/b18cR can swap parts without any problem.
happy modding
Oh actually the B20 is a production engine, but they dont have VTEC like the rest of the B series... The Prelude B20 only has PGM-F1 whatever that is :rofl: (198* models) and of course the 1st gen Crv
1. can i do this?
2. pro n con?
bro...
B16B = is from the ek9 TYPE R. and the b16b cams has higher intake duration compared to B18C type R.
So if you get the B16B head...dont change anything in it....just use that head+b18 block.
the valve springs,cams,retainers all use the b16b one...dont swap anything out.
---------- Post added at 12:46 AM ---------- Previous post was at 12:35 AM ----------
change to hi comp piston...b16b piston
Since all talking bout interchanging part so i curi post awhile ar.
Now I'm running one b16a with 18cr gb, if i wannt swap in a 16b, can I just buy the engine kosong and swap in retaining my old wiring and ecu ?
I don't need the 16b brakes. Can this be done on an eg ?
Yes you can. But u may need at least a vafc to tune the air/fuel ratio cuz ur current ecu is for b16a. Either that or u can rechip... Or... As my mechanic would say... Hondata...
it can be done...but you might risk running lean due to higher lift intake cams,compression etc..
need to get it tuned or re-chipped ecu...
AD_EG,
tks for ur advise.....i can use it too......guess u have alot of experience in hondas.......
u may also need bigger injectors and use the vafc or e-manage or any of those piggybacks to control it....best if u get the type r injectors
since every honda's sifu here,may i ask a question??
is that any possible to fit a k20a high compression piston into b20b block??
and 16a head for the top,would it make more power??
---------- Post added at 07:07 PM ---------- Previous post was at 07:05 PM ----------
b-series injectors are the same
unless u use h-series.
correct me if im wrong :itsme:
there are peak & hold injectors like from obd0 1988-1991 civic/crx/integra & 1992-1996 prelude model(others than with H22)- they have resistor box
the other one is saturated type -obd1 onwards
1988-'91 Civic Si/CRX Si Peak and Hold 240cc
1992-'95 Civic Saturated 240cc
1996-'00 Civic dx cx and lx Saturated 190cc
1996-'00 Civic ex/si Saturated 240cc
1990-'91 Integra RS/LS/GS Peak and Hold 240cc
1992-'00 Integra LS/GS Saturated 240cc
1992-'96 Prelude Non-VTEC Peak and Hold 240cc
1992-'96 Prelude VTEC Peak and Hold 345cc
1997-up Prelude VTEC H22 Saturated 280cc
yeah, its copy & paste:thefinger:
K20A into b20b Block
the thread is old,but got some good info...to answer your questions
bro...
shooootttt... damn, sure im really newbie and zero knowledge bout vtec... before this, i only thought that type R is only in 18c ... *rupanya 16B pun type R ke??/ seriously i dunno...
btw, seriouslyg guys, u re ROCKS!!! thanks for keeping this thread on reply! really appreciate all your reply... owe u guys a big time...
ok, as usual, want to ask a question again... lol .... *malu laa pulak...
1. do all the vtec kick in same rpm? i mean do B16a kick same as b16b, b18b etc etc... *leave out the vtec controller...*talking about stock vtec
2. mine kick around 5200rpm... does it ok?
3. what is the best rpm for vtec to open?
4. other than vafc, what other gadgets that can control vtec open?
5. does the engine oil 'makan' in vtec engine? *coz after a while, my engine seems have to top up a bit... but makan not to much laaa..
6. what are the best management for vtec engine? e-manage good ke? *piggyback only! * no money laaa.. :P
7. hondata is ecu rite? need to tune or just pasang then laju terus!!???
again, i u think im annoying, im sorry coz i admit im very noob in vtec... but i do love em... *especially when it kick... horny mehhh!
u guys always gathering ke? lets minum2 n talk... hikhik
I'm not a pro either but for
1.)Not really the same depending on the ECU, stock b16a2 should be around 5.7k and stock b16b should be at 6.2k,b18cR should be 5.8k if wikipedia did not lie me:biggrin:
2.) Mine engage at 5.7~5.8k. But i think there's quite alot of people who change the ecu chip which might shift the vtec engage point earlier or later depending on the setting of the chip. 5.2k i'm not sure whether is still stock ecu or not but as long as the power band not dropping and quite linear then should be ok.(but alot says the engage vtec earlier doesn't necessarily means more power and some might do harm to the engine)
3.)There's no such thing at best time for vtec to engage. Best thing is to go dyno and map your engine mapping until your engine produce highest power output posible.
4.)There's quite alot of vtec controller available vafc is one of them only, just google vtec controller and u will see quite a few. But changing vtec engage point without properly tuning the AFR will not guarantee u more power.
5.)I think if piston ring broken all engine also will makan minyak enjin lo. Is b16a frequently have this problem or not I'm not sure, at least mine doesn't:biggrin:. The only vtec owner I know to have complain about this problem is a prelude H22A owner but he swap his engine in without overhauling and baught straigh from h/c shop thn transplant into his prelude, so the engine internals might got problem already.
6.)Lots of people claim the best piggyback(piggyback, not standalone) for honda is Hondata S300. But I'm not really experienced in ecu tuning so let the pro answer u better.
7.)Hondata is a tuning company who specialise in Honda ECU tuning. They produce quite a number of ECU for Honda cars. Most time when prople tell u hondata they referring to hondata rechip ECU. Means they take out your ECU stock chip and replace it with a chip from hondata.
All above is juz my dua kupang. I'm also a noobie here.
Now time for my questioning session, as I asked for B16B engine kosong, wiring can use back b16a and just swap ecu or need to buy the wiring too ?
Btw, what's the difference and how to identify between OBD-0, OBD-1, OBD-2 ?
I don't even know what ECU is my b16a running on:banghead:
yes you can...no need to buy wiring..can use back your wiring...
what car is your b16a from?you should have a p30 ecu....you can check yourself bro..check the image below to see how to identify your ECU
about OBD2 or OBD1...from what i know...year 96 and above have the OBD2 ecu's...
