Need some info of 3SGTE again!
TRD.AE92
Hi all,
I found a cheap 3SGTE halfcut from Caldina (98-01 version).. Are it the same performance which are provide by Celica ST205?
I find online, found the different is Caldina 3SGTE no water cooler... and share the same hp with 3SGTE from Celica... So hence, better get a halfcut from Caldina rather than Celica ST205?
that is ST215 caldina 3sgte......cheaper yes but no big brakes....so total same amount too....running plug coil not distributor
if get auto version it comes with tiptronic on the steering u have to install complete if not maybe check light will appear......
what is it actually u need to halfcut for? i see u ask about modded st205, for your st205?
post some pic of ur st205 so next time i see i know it is ori st205...haha
---------- Post added at 11:17 PM ---------- Previous post was at 11:14 PM ----------
mamat can u sms me ur no....i forgot to save it today
auto is around RM3K.....manual is around RM4-5K.......my caldina is using adjustable from this model
sorry, just want to tumpang asking a bit..
Is the tiptronic steering of Caldina compatible with Tiptronic of Altezza ?
looking for possible replacement of altezza tiptronic steering...?
Sorry for hide the story behind...
I actually got 3 fren planed to mod their Toyota SE to 3SGTE engine, because all of them willing to quit from 4AGTE already... Cause thinking of reliable, performance and cheaper performance part too...
And I was the person who recommend them to pump in 3SGTE from ST205 and above... cause as I know the internal part of the ST205 are better than the ST185 and 165... Performance also better.
Anyway, my bro found a Caldina (Manual) halfcut.. Price is RM3,500 only, not sure worth or not lo...
2 of them already found the halfcut, and only just need 1 more to accomplish searching. Thanks for runner afford...
TRDAE92, can you give me location of workshop that are good in swap 3SGE into AE chasis.?
I'm just starting researching whether to get Beams or 3SGTE....
People say turbo maintenance turbo higher, but I've used mazda B6 turbo standard before, no problem.
Maybe if mod, then maintenance will become higher than stock, I thinklah. I Never mod engine before...
My workshop? I not doing at KL wo... If KL you may refer to corollagtouring lo... He should have a nice workshop for u to install.
Maintenance high? Depend on how to use lo... Bigger boost and bigger turbo will short the life span too...
3SGTE is much reliable than 4AGE/ZE to 4AGTE lo...
me oso wanna add a Q...
if using intercooler top mount tat using water cooler..(sorry dont know exact name for this)...isit posible to make it to front mount???? like normal intercooler..
I worry it not going to work. The water level problem.
---------- Post added at 10:42 AM ---------- Previous post was at 10:42 AM ----------
No ideal... I never use tiptronic before....
fed up with 4agte and swap with 3sgte?
why?
how much dyno 4agte will produce? care to share?
if on ST205 the eng light will turn on.....so i use MR2 3rd gen onward ecu no problem.....or either that u can try remove the water cooled "water level sensor" and tape it up so always maintain full and no check light on, 1 guy did that when i sold him the 205 wiring to match with his 185 engine
why?
Sorry I dunno what thier dyno result... I think they fed up with 4AGTE lo, but not sure is real or not...
maybe this question had been asked before..
my car is running st185 3sgte engine..
can i upgrade the engine + all wiring using the caldina one?
donno which version..
but it originally come with auto or mayb tiptronic gearbox..
can i use the auto gearbox to my car?(corona st171)
or can i just use manual gearbox that i use now?
thanks in advance
thanks in advance
You much identify is Tiptronic version or auto version.
Both need to match.. example:
3SGTE (ST185) + Caldina gearbox (Auto) + Wiring & ECU (Auto) = Working!
3SGTE (ST185) + Caldina gearbox (Auto) + Wiring & ECU (Tiptronic) = Not Working!
Anyway, if you plan to upgrade or heavy use the engine... I do suggest you take the engine from ST205 and above.... ST205 and above is an improved version from ST165 & 185... Internal part are much stronger and last more lasting...
so, if i use st205 engine + st185 manual gb + st205 ecu, can it work?
or if i transpant the whole halfcut, can it fix st171 chasis?
st205 version still use afm or use map sensor?
ST205 MAP sensor!
st205 engine + st185 manual gb + st205 ecu = work!
ok sifu..
thanks for ur info..
i'm relatively new with this engine..
use blacktop before..
dun think u can use either ST185 or ST205 gearbox coz both of this is 4WD.......ur corona should be Front wheel drive only
