While cruising, usually at low speed, the engine would suddenly like died when I decided to step it up and make some speed, but its not really dead because its still running just that out of the sudden, it lost the normal sound from it's exhaust and sounded like 'spitting'... and at the same time even if u full throttle, it just won't respond to anything but 'spit'... I would need to downshift another gear, give it some rev only it would come back to normal.....
It would happen more frequently while the engine is still cold. No check lights came out, checked my plugs, seems to be still healthy. Could if be the plug cables? injectors? or anything worse..... Anyone of you all faces the same problem B4?
