- Joined
- Jun 4, 2006
- Messages
- 2,798
- Points
- 1,683
haiz.... sad story... thanks for sharing..
Guys,
Need some advice.
Just bolted on and am running without management.
Using a recond td04 and no idea whts my boost but i was told its around 0.3-0.4 at most (claims that the ecu will not let it go beyond that) so its an auto cut off if that happens.
Thing is, i dont fancy the installer because he tends to over-charge me ALOT and from what i see, the bolt on thats done on my car could be done wayyyyy cheaper. Workmanship? In my own words, i would say meh..below standard.
I even doubt the promised samco silicon joints. Gona double check on it later.
Slammed in a Jasma IC and told me its custom made piping. Even the piping is not done according to my car as its abit high up my bumper. Somewhat, i would say, short?
K nvm, done with the QQ for now.
My prob is here, he told me i should use e-manage blue at least and tells me he would kawtim everything at a reputable shop at sunway with all the harness n dyno tune etc and also a 1000cc injector @ rm3k+.
My question here is, is it safe to omit the management system for now?
I tried boostin alil and i got fuel cut at around 3.5k onwards mostly around 4k.
Its liek, spools, then jerks alil at 3-4k, spools again all the way smoothly. Did not go beyond 5.5k rpm cuz afraid might be not enough fuel. Does this means i need bigger injector (1000cc is crazy) or simply a walbro fuel pump suffices?
Hope sifus can help me clear some doubts on this.
bro damndamn, if im not mistaken your car is a gen2 turbo? :)
bro... pls state wat engine u using ...
wat the heck u need 1000cc injector for...? abit the too much .. hahahaha
. How did u figure bro changchewsoon
.Hmm,
Mayb i should ask him again for the breakdown.
Just went to my usual mech and i got spits all over me. The workmanship is really really bad and a definite over-charge. Went to another workshop as well and got the same comment.
So bro, do you recommend me to that shop for piggyback as well?
May i know how much would it roughly cost for the haltech interceptor + install + tune?
To be perfectly honest, i do not trust his pricing anymore. As much as i would like to go to the tuning shop behind him, it wouldnt be so good.
Further, ive asked my mech friend and he says that he's never done anything on campro turbo with e-manage so he wouldnt know if it will work.
Another concern is, each tuner has their own ways of doing thing, so i think its best if i just stay with 1 rather than switchin and having to end up with a massive rojak setting.
. Shy la to say hi..hahaha
Hi guys,
Yes, i am drivin a gen2 BOT but im too shy to say it out cuz afraid the reliability issue definitely will pop up. We all saw the stickied post.
Eg: My friend and i 100% heard will be getin a td05 but end up on a td04, intercooler was downsized out of nowhere cuz afraid of lag. For the price and im not even getin a stainless steel piping and the weldin job, omfg. I dont even wna start on my hose and air intake crap.
I bet with all those info, most of u, if not all could have slightly figured out who this person is![]()
And yes bro Speed n Stupiddog, i know 1000cc is crazy. Im not so sure if by what he ment 1000cc refers to 250 x 4 ? No idea. Anyone here has any idea whats the stock injector cc for gen2? Sidefeed/topfeed etc? Might try with mayb 4g93 if it fits. I think i heard somewhere there's liek just one 1000cc main injector or something like that? anyone can clarify?
Am thinkin of changin injector and fuel pump to solve that. Do i need a regulator? By that, what i mean is, can i run my car with jst changin either 1 for now (injector or fuel pump or regulator only)? Runnin tight on budget![]()
Oh and i forgot to add, do i need a piggyback or anything once i put in the fuel injector,pump,regulator etc?
Should i at least run for a dyno with no management just to be safe on my air fuel side?
Last i heard, a normal piggyback liek safc etc cant "cheat" the ecu and will constantly resets itself.
And till date, only certain shops and him can figure out how to successfully "cheat" the ecu.
Mayb i should find abang cipan and c wht he says. Gona go n snipe his blardy kittens n cats again.
oh bro damndamn, i think i know who did the BOT for you and i also think i know which shop in sunway he is recommending you to go do your piggyback and tuning.
he knows me as well, you can ask him. im driving a vios turbo.
you definitely need a piggyback for sure, just want to share with you that if u're getting e-manage it can only do air/fuel and not ignition timing for your gen2. i know budget is a concern here, but in order to really produce power and increase the drivability of the car, you need to be able to alter your timing.
haltech interceptor is a good choice, but still if u decide to go for an e-manage its still good.
and well, as for the 1000cc injector, its definitely a 1x1000cc injector and not 4. it will be nightmare to solder on 4 extra injector and u'll be running 8. so its definitely a 1x1000cc injector.
Hmm,
Just went to my usual mech and i got spits all over me. The workmanship is really really bad and a definite over-charge. Went to another workshop as well and got the same comment..
To be perfectly honest, i do not trust his pricing anymore. As much as i would like to go to the tuning shop behind him, it wouldnt be so good..
well, i had my turbo kit done by GT Auto in sunway and i will never let anyone besides them to touch my car. their workmanship and tuning skills are well know, i don't have to keep repeating it.
so if u asked me whether do i have anyone in mind for recommendation, i will only recommend GT Auto and nobody else.
im not sure about the details of the haltech interceptor, u might have to get a quote personally from them but i can assure you their pricing is fair and they will do a good job.
however, since your mechanical work is done outside so the tuning can only do so much for you if the problems lies in the mechanical work.
and u're right about sticking to one tuner, which is what i did. but again, i think u can't totally listen to what other shops have to say because they're all competitors.
there was once i sent a friend to collect his car at another shop, the owner of the shop saw my car and asked me to let him check out the engine. after that, he made all sorts of sneer remarks which is total bullshit because i knew exactly what my shop did for me.
he's just trying to put down others hoping in return there's a chance i'll listen to him and let him do some work on my car. thats the thing i don't like about other shops, they're not able to give credit which is due to people.
whats wrong saying that your tuner did a good job on your car and his workmanship is good? one doesn't need to step on others in order to make himself stand out. instead, i would have respected him more if he went along the lines of saying something like he thinks he's also very good, give him a chance or something.
anyways bro, before i go off topic it seems like u're kinda upset with the whole thing huh? damn, im really sorry to hear that. wished there was something i could do to help.
Lol yes bro, im drivin that gen2. Always see ur car around too. Shy la to say hi..hahaha
And bro Chang, i definitely will go to GT too but im just afraid its not so nice to go behind him.
Would you believe me if i say i only saw him(the installer) twice and he never really explain much to me about anything? Be it the things im getin till whats the pros n cons.
Like i mentioned earlier, i might be an isolated case. He was on holiday and didnt monitor. i dont know.
Just checked the turbo today and it seems liek its a single fin td04l which i dont even know if it has been recond or not. Seems liek just took our from some warned out pajero and plonk in.
Believe me if i post the pic of that turbine here, u will go WTF. Look really really horrible.
I dont even wna mentioned the amount of new scratches found on my fender. 100% is caused by rings on their finger. sigh...
Because my battery was relocated, those wires are..really messy now. They really either did it half hearted or no heart at all.. and the installer was tellin me "dont worry i sure kawtim leng leng for u, i also got reputation 2 jaga blablabla".
And bro, to be very honest, i myself as a layman can see that the pipings are cincai done. Went for second and third opinion and all say the say. The flaws are really really obvious to the naked eye. Lol how sad. Even i show to my friends who are not mechs also went WTF why so uglyyyyyyyy..
What my mech friend say is true, Turbo should be either the final or middle stage after some NA mods, not the 1st stage. End up i still have to get all the NA stuff liek Fuel pump, regulater, injector etc. Goin bone stock on turbo is jst plain crazy.
One thing is my mech friend sux, he say dont feel like touchin my car now (as thou he has to clean up a mess). Dont blame him thou, its really bad. The only reason i went to this fella for the BOT is because he has done alot on campro so i thought standard is definitely there and hassle free. Mana tau..lol.
I think now gota end up with no boostin and save for a haltech + fuel pump + regulator + injector + etc2. I think total cost will be same as plonkin in a GSR..lol
Oh and bro Chang, thanks for the good thoughts..lol.
i boost 0.5 also using 450cc consider big d.. 1000cc i dunno how 2 drive d.. hahaha
bro damndamn, if urs campro engine is running stock siemen ecu, unichip is the only one can do piggyback wif it, else standalone like haltech which SURE cost higher
i happened to know someone from penang boost stock internal campro for 0.5bar using unichip n did a good tuning that running for around 1 yr the car is in good condition without much problem that the amount this guy spent was around 5-6k if not mistaken
well, for my camPUR engine, i would juz use Additional injector controller to control the extra fuel :P
only nx year i'll do BOT on my neo as budget is running out these few months -.-
