satria rear disc problem
CyborgR
Perak
i having trouble with my satria rear brake issue, there no direct response after pulling and is not grippin at all after i pulling it, make me hard to even engage a handbrake turn, is there anyhow to improve the rear brake system??? the disc and pad are quite ok still, i wondering why it wasnt gripping at all..
thanks :confused:
i service the caliper, change to new oil seal for the caliper, then change the handbrake cable, then its ok, but not sure if u need to change the handbrake cable or not....
so u mean when u dori dori the rear disc doesnt bite enuf o the bite is so poor its like nothing?
yong: its like nothing,that y quite frustrated
8229: i will check the cable and caliper, thanks mate
but my gen2 rear disc handbrake work like wonder...damn can i just swap into it..gosh
u try to loose the hand brake cable. after tat u pump the the brake pedal more den 30 times, if can pump the brake wif engine start. after tat u tighten back the handbrake cable. should be ok after u do tis.
i see, orite mate, thanks alot for the advise, and btw i do it with engine started ya?
better if engine start coz easy to pump brake fluid into rear pump.
just tested it, its better then before but handbrake pull still cannot stop on the straight...the mech said possible the cable are too long.. its so damn troublesome, guess hydraulic handbrake is my last solution
hydraulic handbrake is not a solution... hydraulic cannot withstand high pressure for long period of time... datz why handbrake use cable...
ya..have to giv up autokhana or just join without using the stupid handbrake..sien
---------- Post added at 03:33 PM ---------- Previous post was at 03:33 PM ----------
ya..have to giv up autokhana or just join without using the stupid handbrake..sien:banghead::banghead::banghead::banghead:
make additional hydraulic ebrake lo..
me use toyo R1R 205 behind my car. i use hand brake oni can be lock rear wheel wen cornering. wen straight never lock. i test tis after i full overhaul my rear brake piston n re-oil my brake cable. now pefromance quite good.
