r3 wit high cams!!!
go for a well known gud setup that people normally do laa
RPW cams are good but quite expensive,JUN also damn expensive, i can get for u kelford for 4g93.. as for ecu same laa 4g93 ecu..can be tune with piggyback..dun simply port ur head..N/A engine diff from turbo..
The ECU for the earlier batch of Putra, Satria Gti's 4G93 engines are running with Mitsubishi ECU and it uses air flow sensor. Whereby, the later batch of Satria Gti, manufactured year 2001 and above are running with Siemens ECU, uses MAP sensor. Those Siemens ECU are not compatible with the E-manage Ignition harness, therefore the Ignition firing can't be tune.
aha...heating issue...its always common stuff with any type of machine...be it engine,cnc o watever machine...heating and vibration is always the big issue...
do u know tat a lot of rotary engine out there have to chg 3 core aluminium o some even cooper radiator,distilled water with redline water wetter just to keep the engine temp optimum level yet onli boosting 0.7
so u just need to get urself better cooling system
R3 produced their own performance parts if i'm not mistaken,they got their extractor,cams,r3 ecu is basically the same as 93 ecu..the engine is the same..
R3 satria runs on VDO ECU tuned by R3 , you can't plug the R3 ecu on normal VDO Satria GTI it won't even start =)
R3 camshaft's lift and duration is higher than normal satria GTI
R3 Camshaft > SGTI & Putra > MMC 4G93(Normal 4G93 from japan halfcut)
---------- Post added at 06:21 AM ---------- Previous post was at 06:19 AM ----------
as above wanting to know if it worthy fitting cams 272 on a r3 engine without mod block!!! so standard block wit p&p head control by afc neo!!!!! wit do u expert guys think!!!!:listen::driver::rolleyes::biggrin:
R3 with high cam will have problem with aircond idling even though you have FICD and extra air suction since you can't adjust the idle RPM, unless you change to MMC Wirings
4gna!!! thanks for the info bro!!! eeeemmmmmmm shall i do it or not!!!
oh ok!!! where is that ah bro!!???:banghead::banghead:....
give proton a ring and ask them about that =)
can't guide you because i went there with my friend and i was sleeping all the way until my friend wake me up when they want to jack the car up for camber setting
Well go for MMC wiring is for long term, no way you need to pay R3 a visit when you want to upgrade something.
anyway you just need year 2000 GTI wiring & ECU, ignition coil pack, airflow sensor, throttle body can get in like RM2300+ or less
There is no difference between the R3/SGTI/Putra stock camshaft. They are all using standard 4G93 cams. The only difference is the R3 has one adjustable cam pulley factory fitted (can't remember whether its the intake or exhaust pulley).
intake bro!!!! yup all using 4g93 cams for na!!!! not sure bout those from japan!!! gsr!!! i heard the lift are diff if u using gsr japan cams!!! correct me if i am wrong!!
my prev 93 NA cams set up was gsr93t turbo cams just on exhaust side..have tried using both cams on my NA,doest work..why ?...93t cams on exhaust side has higher lift bcos it need to concentrate on producing more power before it goes to exhaust then turbine..whereas NA cams concentrate in intake side bcos power of NA engine depends on how much air intake volume
got info from 1 workshop...
among all 4g93 / 4g93t camshaft.. the highest lift & cun duration is cam shaft from satria GTI yr 2000 yes.. yr 2000 only...
