yup, i know. i'll check it.
i think my fuel regulator is leaking cos i could smell petrol strongly. could that be a factor as well?
or u could use a lighter...Use ur finger and touch inside out of the afpr, another factor for strong smell petrol is engine is running rich.
Mel... how much money you spend at powerzone?
Really got hp increase?
As many sifus have mention... you are running super rich after 4000rpm... 12.++ Air fuel ratio for turbo/vtec spec.
NO management at all, but after 4000 rpm all of a sudden becomes so rich, WHAT did they do to you car? DID they "modify" you ecu?...
Or they just throw in the fuel regulator and up the pressure giler giler? (now maybe already become rosak...)
You know the cam specs? TQ
wtf... powerzone tune the car to run rich like this at 4k rpm??...
i never did any tuning at PZ. i only bought the exhaust system from them. the PZ cam is 2nd hand item i bought from my friend and installed at a different workshop.
i'll try removing the fuel regulator tomorrow, and see how it works out.
i did the tuning at under5. they did a few runs on the dyno and they said that this is the most efficient setup.
not them. under5.
Correction...How much money you spend on 2nd hand powerzone stuff?
Under5 tuned what or how to tune...?... can only set da PZ cams and just up the Fuel regulator.
and dynoed...You have no "management" aka piggyback... so i guess that would be the best they
can do...Need to throw in more money... of a least a RM450 5 button SAFC...
TQ
TQ
he bought the stuff from another friend with a good price, and we know the fella as well, so there is no need to worry that the cams and the full piping set is broken.. can cut that out of the list..
and what he did in Under5, if im not mistaken is just fuel-reg tuning.. yeah, safc might do the job, but we are trying to solve whatever the problem here first, since buying safc will involves alot of money.. XD
previously jombiee and shinjite suggested a compression test, i think we should go and do that first to see if there is any "internal-injuries" in your engine. I was running high-compression with auto GB and atf cooler last time and there is no problem achieving top speed and pick up, you should know. Only after the engine overheat, then i never overhaul it, i start to lose compression and speeding is not an option anymore.![]()
If there is none and the compression if all fine, maybe trying safc is the next thing to be done..
mel, if you ask skyline_maniac, previously he did his fuel tuning in Under5, turn out that it is abit wrong, not that i say they don't know to do job, but maybe a slight mistake.. his bolt-on 91 is all fine now after doing it in MAG (Mal Auto Garage), it was too rich previously at Under5 as well..
where can i do the compression test? MAG? how much do you think it'll cost?
jom Pandan Indah.. takdek hal..
check your clutch. it may be slipping unnoticed.
if got explosion means there is a leakmind to tell me how will that work?..
