- Joined
- Jan 11, 2007
- Messages
- 1,342
- Points
- 5,148
yea IF the 4G15 head bolts on, then i'm guessing one hafta source 1 pc enjin kosong fer misc parts like complete intake etc.
but the idea IS very appealing![]()
stock 4G15 dohc 16V head & complete intake, 4-2-1 extractors, freer-flowing muffler, a good CAI kit (take a pick at the blinding choices available nowadays), better spark plugs & cables and a piggyback to complement the whole setup.
rm2K budget sounds like enuff dy hehe
it's gonna be like a 4G15, but with bigger bore & longer stroke.
gud idea arr?![]()
good y not good haha
u can get super cams from RPW, they've played around with the dohc 4g15
oooo...really ar?i tot it should be faster if change to mivec g/b as it has shorter ratio..but then,maybe the mech did not do a great job kot..hehehe..maybe he did not install it properly?who knows..but most of people told me that changing to mivec gearbox should giv an increase in performance too..
no it wont be faster, the mivec engine is high revving, has power all d way to d top, not d same as the 4g18 where it runs out of breathe fast, but has a strong low to mid...
only if ur 4g18 has power right to the end of the powerband than possibly u will benefit from the mivec box swap
about the powerzone one, no nothing to do with the mechanic, once u pasang and can run edi without problems already means mechanic did a proper job wat :P
there is a reason y car manufacturers came out with the respective gear ratios for the respective engines; it is suited to the powerband/nature of the engine
for torquey, not so rev-happy engine, u need longer gearing to make the most out of it, so dun worry about the stock gear ratios, it would be one of the much more advanced mods
or from Mitsubishi Colt Ralliart Version-R is a 4G15 DOHC Mivec head
heh keng....wonder how much that would cost
, i'm looking for the good condition original 350Z exhaust. If you want to let go your exhaust please let me know ya..
