- Joined
- Jun 4, 2006
- Messages
- 2,798
- Points
- 1,683
Jinkl .. What I know is... althought the power is different.....but as long as dont boost over 0.7bar....
if using td04 boost 0.6 safety.... I think there's no problem too if use TD05 boost 0.6bar......
boost kill engine
boost kill engine
DON'T ASK HOW MUCH BOOST UR ENGINE CAN HANDLE... ASK HOW MANY HP UR ENGINE CAN TAKE...
That was the last answer I've received from a anonymous website from US... Taiko... Ammount of pressure controlled is the same, but the ammount of air delivered is different. Why not set the targetted HP before started to ask how much boost ur engine can handle... Then u begine ur modding from there...
if tht theory is correct , why dont u try gt35 at 0.6bar boost :)
---------- Post added at 01:44 AM ---------- Previous post was at 01:40 AM ----------
actually boost doesnt kill engine
detonation and lean AFR kills engines most of the time
the higher the compression, the higher octane fuel u need or the more u need to reduce ignition timing
the higher the compression the harder n precise the tuning has to be with BOT, its like a timebomb waiting to blow
b18c can , bt mouting wise its nt gonna be easy , n u have to be nice on the wallet when police or jpj stops u
Good one Jinkl... Muahahaha....
err...do u have any idea how many hp will increase if a td04 bot done right n tuned right?
i guess 20hp...mayb 30hp...doesnt feel good?
Urm, tdo4 coupled with what other modification...? Have to consider the whole set up... not just the turbo..
Example, 4G93 and 4G93T(td04L) basically the same engine. Well, intake/exhaust, cams profile, pistons and injectors are different... But crank HP is abt 40HP difference.
20 or 30hp ?? If me... I better stay at N/A and go for High cam,high compression pison..etc :) confirm above 20hp.. and... it cost more cheaper than BOT...
20-30hp..? I think u'll spend more than 4K for the 30hp increment...
NOS, is the most direct way to achieve 30HP... Stock internals... Is the reliability issue...
veilsideboys...u think for NA really tat easy 2 get 20-30hp?
do u know how much u need 2 spend 2 get a say b16a to gain 20whp?
Correct boss...
