AMT Coil Spring Buffer / Cushion (Promotion)
yongfei
LABOUR DAY PROMOTION : RM 60 / BOX ( school holiday promotion )
WANNA extend your car's spring & suspension lifespan ?
AMT COIL SPRING BUFFER
Package includes: 1 box: 2 pieces of CSB (Coil Spring Buffer)
Selling Price = 1 box is RM65, 2 boxes is RM115
-KOREA technology (1 year warranty)
Benefits of using coil spring buffer:-
- Helps restore spring tension and lifespan
- Extend lifespan to sagging coil spring
- Reduces noise and vibration from suspension component (ngek ngek sound)
- Improve stopping capability, Enchances drivability
- Fast Installation and Result Oriented
- Suitable for all types / modal of vehicles (only Ori and OEM Coil Springs)
Sizes Available:
1. Model A: Spring Clearance (47mm) / Spring Thickness (13mm)/ Spring diameter (173mm)
2. Model B: Spring Clearance (35mm) / Spring Thickness (13mm)/ Spring diameter (160mm)
3. Model C: Spring Clearance (27mm) / Spring Thickness (10mm)/ Spring diameter (131mm)
4. Model D: Spring Clearance (23mm) / Spring Thickness (10mm)/ Spring diameter (113mm)
5. Model E: Spring Clearance (15mm) / Spring Thickness (9mm)/ Spring diameter (112mm)
6. Model F: Spring Clearance (12mm) / Spring Thickness (15mm)/ Spring diameter (120mm)
How to measure your spring?
Available stock for Various Car Models
Forum: http://multiplanforum.active.ws (for picture gallery)
Website: http://multiplan.active.ws
Email: [email protected]
Call / SMS: yongfei - 016 - 238 3237
Maybank detail:
MBB Acc: 1010 5809 1666
Poslaju: TBC Later (this stuf is solid and abot heavy, so...)
DEMO:
P/S: AGENT WANTED FOR ALL AROUND MALAYSIA !!!
Bump: bump bump bump
cny promo...pm or call for best price..
what happen if you install the wrong size.eg..my car is sentra 06 and refer to your table i should buy size A for front,but that shop recommend me to use size D.Now after install i didn't feel any different between before and after.It is because installing the wrong sizes?
bro, item stil under warranty...if really wrong size then u can go and exchange from where u bought....tq
