- Check diagnosis error code...
- check AFM pin connector...make sure it's secure tightly...
- check park plug, cable plug and distributor all in good condition...
- then...reset your ECU...see if the trick works...
I just installed an evo 3 spring + absorber (front and back) but the half cut shop gave me a wrong combination. The front is now around 6 1/2 fingers height and the back is only 2 fingers. Would there be any problems...
