Radiator Fan does not start.
hwsv07
hi, have a problem would appreciate some help.
quite scary cos the temperature shot to 110 and i quickly turned it off.
I understand the Radiator Fan supposed to kick in after a certain temperature. (I think about 90c)
Weird thing is,sometimes the Radiator Fan runs when I switch to ON (engine not started). but it cuts off after a while. Then when I start the engine and temperature rises, the Radiator Fan doesn't start.
I've checked the Radiator Fan Relay and the Radiator Fan Fuse. Both are working.
help! is the thermostat sensor spoilt? how do I fix this?
thanks a million
Post your PM your email address and I'll send you the manual on how to check your thermostat sensor.
