Soundstream Lil Wonder III LW1.800 800W Monoblock Amp Class AB
ICE -In Car Entertainment
jimmylim85
Specification :
Soundstream Lil Wonder III Series LW1.800
800 Watt Mono Block Amplifier
'It’s all-new, awesome, and Soundstream at its’ finest! The entire Lil’ Wonder III line-up of amplifiers has
been revised from the inside out. From the sleek and stylish new chassis to the cleaner, more stable
internals, the new LWIII amplifiers are sure to impress all who indulge...
Common Features
LED Power and protection indicator
High and low level input
Selectable X-over: HPF/Full/LPF w BPF capability
Continuously-variable low pass crossover: 50Hz-4KHz
Continuously-variable high pass: 15Hz-500Hz
Bass boost: 0dB / +6dB / +12dB
Soft turn-on circuit
Mosfet pulse width modulated power supply
Remote subwoofer level control: LW1.400 LW1.800
Increased efficiency by 10-15%
Higher S/N ratio due to new circuit optimization
Lower THD due to modernized circuitry
Higher damping factors for better drive control
Improved crossover filters
Upgraded output transistors for improved reliability
Better ground isolation for less noise
Increased protection to reduce speaker damage
Increased linearity on bass remotes
Specifications
Power 4ohm: 400 x 1
Power 2 ohm: 800 x 1
Power 4ohm Bridged: -
X-Over Freq. -
Dimension 500x52x205
ORIGINAL from M.A.T with 1 year warranty. Brand new set.
PRICE : RM 1100.00 each
Postage rate : West Malaysia RM 30 / East Malaysia RM 70 (POSLAJU or Skynet)
* Price might change without prior notice due to courier service charges*
How to order?
PM or email me your order model and particulars such as name, mailing address and contact number.
COD takes place only in Ipoh Perak with 50% deposit (non refundable)
Contact number : 012-5356922 / 016-5506922
Email : [email protected]
demo got warranty?jz cheap RM110 ler..
actually i using below this monoblock,can i knw it this LW1.800 powerful than my i using this 1?
NIGHT KIDS D76.M 500W RMS X 1 Channel Monoblock Amplifier- 1-Channel Operation
- 1x500 Watt RMS
- 1x1500 Watt MAX
- 1 / 2 / 4-ohm Capable
- Ultra-Clean Class-A/B Amplifier Design For HQ Sound
- High-Grade MOSFET Outputs
- Dual-Core MOSFET Power Supply
- System Diagnostics LED’s
- Sound Shaping Controls:
- Subsonic & Low-Pass Crossover Selections:
- Subsonic Adjust (15Hz to 40Hz) Low-Pass Adjust (40Hz to 150Hz)
- Bass Boost, 0 to 12dB
- 1x500 Watt RMS
- 1x1500 Watt MAX
Yes, comes with 1 year warranty.
This Lilwonder III LW 1.800 is more power than your current Night Kids. Even the amplifier length is 19inches.
