hahahaha... hardy meet the same old... ahahhaa
hahaha... sama sama.. i use to own a passola when i was in secondary school (20 yrs ago), add 2T kao kao... the smoke so thick that all motobike siam far far behind
now damn kao annoying when saw bike with smoke
guys it is difficult to get a FD rated clean synthetic 2T oil...shell advance the most expensive 1 also Fc only and it is a semi synthetic....any recommendation for better 2T oil so that it burns cleaner?
Heard lots of rotary owner doing that but never heard piston engine owner doing so, the lubricating effect sounds reasonable, but will it clog the fuel rail or leave more carbon deposit in the engine?
When putting 2T, need to beware of the flash point of the product. I put a Yamaha 2T tank onto my car and direct inject 2T into my engine combustion chamber. Normal 2T or even 10w30 engine oil are ok. But when put Motul 800, thick carbon formed and CEL popped up and said system too rich (means fuel not fully burned). But I rarely heard any Malaysian is doing this stand alone tank deal. Most just pour into their fuel tank. In this way, 250ml or Motul 800 for 60L of fuel is still safe. Normal syntactic 2T (RM2x-3x per L) can put up to 350ml/60L without a single problem. I'm now having Royal purple 0w20 in the 2T tank while engine oil is RE-A Super G 10w40. Anyway, FYI, there is a product called RCL from Torco. The purpose is about the same but it was made for car use.
For the performance, the lubrication only helps to make the engine not to struggle for going up high rpm (can hear the sound when revving). HP or torque or even FC wise, maybe got a little bit improvement but not worth to mention![]()
For the ashless deal, I don't wanna argue much. Just put 1 drop or 2T onto aluminum foil and cook it on your kitchen stove till it burnt off. You will know if the claim is true.
What I reckon is, after use premix (2T) for let's say 10k-20k km, should stop for 1 tank and put BG44k to clean up the system (maybe the O2 sensor(s) too). I did open my fuel pump assembly and found a little bit sludge on the fuel filter when putting 2T into fuel tank for too long without cleaning. Normal car, should replace the fuel filter earlier than scheduled.
), some 2Ts are capable of cleaning up the combustion chamber... An example to that is Maxoil TCW3 2 Cycle/Outboard Oil..... I have never tried it out myself though coz cant find one at my place... Outboard oils (used in 2 stroke motorboat engine) tends to clean up the combustion chamber better, but whether it is suitable for higher revving automotive engines is still an issue....From what i have sourced from the "rempit forum" (), some 2Ts are capable of cleaning up the combustion chamber... An example to that is Maxoil TCW3 2 Cycle/Outboard Oil..... I have never tried it out myself though coz cant find one at my place... Outboard oils (used in 2 stroke motorboat engine) tends to clean up the combustion chamber better, but whether it is suitable for higher revving automotive engines is still an issue....
Another thing to note is the price of the 2T oils itself.... A normal fully synthetic 2T with TCW3 and JASO FD might cost somewhere near RM40... even a mineral one from Motul ( which I'm currently using on my second wife) is around mid 20 bucks.... Thus, a good 2T oil might be more expensive than what most of us would expect...
For rotary engine cars, the act of mixing 2T oil to the petrol is called "Premix".
For normal piston engines, it is called "Upper Cylinder Lubricant".
An alternative to 2T oil as a "Premix" or "Upper Cylinder Lubricant" is Marvel Mystery Oil.
You can buy it from ACE Hardware Store.
any significant effect..??
