congrats! getting the one from ZTH marketplace? make sure you do a full lube change once you get it, and keep servicing it on time with the right oil. FC of our cars (I drive a 7) are quite humble as long as you keep your foot light, but then again, will it still be an Evo if it's not trashed? :D
despite all that, the world of ownership for this machine will not let you down. all the best!
Hello eujin,
Welcome to the E world :wavey:
Base on your Q:
Reliability: Since your ride is automatic gearbox, have to be careful due to part availability. But still you can blast till max (speed cut limit) slowly. install boost controller, meters & oil cooler
The things you need to look after: check your AYC, all suspension, bush, bearings, water pumps, tensioner, cable, hoses, check lights, turbo or basically all item in engine section, checking using MUT II also to find any problem (if any).
Maintenance: 1st day, change all wear & tear such as timing belt, balancer belt, water belt, AYC oil, gearbox oil, LSD oil, coolant, plugs, battery, water pump, Tyre, brake fluids, brake pads
fuel consumption: base on my friend (he also use E7 GTA stock mod), fuel capacity approximately 40liter could only last 250km without blast (only town area).
I did all the checking + changing when I get the E.... expensive oooo.....
Happy riding....![]()
wow! that's crazy! I still can get about 300km+/- on full tank if I drive off boost after recently changing to Motul 4100 (actually dont know if got relation or not la, just happen to change this :P) but once I went for track day, and the end result after much trashing I only got 50km (10-12 laps + rounding here and there?) for half tank!
If possible, get an oil cooler for the tranny in order to protect the gears n the oil!!! Then must use good quality tranny oil too, as it will save u lotsa trouble... By adding oil cooler and using good tranny oil, it will prolong the wear n tear period...
As for fuel consumption, by adding a after market ECU might help reducing it... Make sure u communicate with yr tuner on this, as u r aiming for fuel consumption n not onli giong for high HP from the tuning... They r able to do it... Cos normally a stock Evo, the fuel being used/set r much higher, thus to protect any hipcup!!!
Yeah, besides all the above mentioned, the 4WD gearbox oil change oso very important... Like the AYC n stuffs...
Cheerz and have great fun with yr EVO GTA ya~~~ ^.-
eujin, my friend just got a GT-A 7.5 and he first put a Apexi RSM to un-cut the engine and turbo timer ( Good), then he add boost controller ( need to weld the manifort ) add Air fuel regulator and it is a bad ideal as the engine check light also come out.
when he want to turn it back to stock, due to welding, he need to replace the turbo and the boost controller can not be use too. we dont know where went wrong but if it is GT-A, i prefer to keep it stock, my E7 i just add meter, exhaust, suspension plus some minor items and keep the engine stock and i am happy with it ( we not racer mah, why need a monster for?)
hope you enjoy your E!!
for my Evo8MR (manual), at town area, including short distance highway, boost or without boost giving me the same fuel consumption = 40 Liter for 250km (RM0.30/Liter at RM1.92/L).
it all depends on your foot.. hehehehe
im planning to get evo 7 gta auto...do removing the 4wd system will give some better FC?
Hi to all,
I just got a used MR-S (this is the model known in S'pore) last week.
It comes with wide bodykit, aftermarket exhaust system and SSR...
