Bro Vagabond, check this out..at the risk of sounding stooopid ..... what are RSR springs???
Hi Guys,
Need to find out from the sifus. Where can I get my hands on RSR springs? Any dealers or shops selling it.
thanks..
Hizam..
Why not coilover terus?![]()
Hizam, in addition to the lowering spring, you can lower your centre of gravity by using spacers for the wheels to increase track width. Same goes with wheels with different offset than stock.
Farouk, I've bumped to this video of Dc5 going downhill & uphill roads, but using a different setup of tyre width for front and back, it uses 235 front and original 215 for rear. What is the advantage of this setup?
@wafs
its good to have you onboard. your knowledge on the subject and your willingness to share it is indeed very much appreciated
A good handling balance must have good roll control front & rear, balanced understeer/oversteer characteristics on selected corner, engine power matched with handling set-up. Good roll control in terms of roll rate and roll angle.
Like the set-up 235/215 mentioned, the car must have a powerful engine...for a FWD car with powerful engine, the car has tendency to understeer, so to counter this thats why it needs a oversteer set-up to counter this. Maybe they already tried with damper setting and geometry to get oversteer but still can't settle the understeer thats why they use the 215 at the back.
For the staggered tyre size set-up at Sepang it depends on the level of suspension mods you put in the car. No need to use a staggered set-up if you can set-up the car to be well balanced as I mentioned before.
If by using this set-up the car is oversteering in character, then for tight corners and hairpin, an oversteery set-up helps a lot. Long corners is quite subjective with this set-up, some driver finds it okay but some will find it difficult to drive coz a lot of concentration must be put to maintain the car on its cornering line...just a sudden steering input and the car tails out...so a smooth driving is required. Not all driver has smooth driving skill.
From what I'd seen, DC5 race cars here don't use staggered tyre size during the race. This might be due to the organizer already set or provide the tyres...so no choice. And for endurance race, the tyres are rotated front-back so same size tyres are prefered.
If endurance race is not taken into account, another reason is because they already managed to set-up the car geometrically, ride height setting, spring rates, the use of spacers, staggered rim offset, specially selected antiroll bar diameter and spring rates where with all these a staggered tyre size is not required...pls take note they are using racing slick tyres where the tyres have very high traction/grip and high limit of slip. The tyres are not easy to lose traction. So, geometry setting of the car is more influential on race cars set-up.
So, for us, better tune the car with available components in the market first. Then, if still fail to get a good set-up then go for the staggered. But, if you want to shortcut and cut cost, by all means use the staggered tyre size set-up which what i will do next. Just make sure you already have a good roll control.
Azrie, try to tighten your rear rebound damping until it reduces your rear roll. Let me know the result. We'll try settle the rear roll first. Let me know the result.
nice ride.
...now..it's time to thank for a good work done by Kit and his crew...Well, I have to...
