Kc extreme wet sanded & acidised restoration detail
kc2
SOS....
I got a distress called from my neighbour that his colleague car has splashes of acid causing the white spot on the paint surface
WATCH out for these guys..(M'sia A/C usually fitted on top )
..picure for illustration used only
I should not have meet up with him at night & as many thing wouldnlt shown up under street lamp & bad finding. Deatiling appoinment set for !st Jan makr a begining of a new day for a new year
I got a shock to find out what actually happen under day light when i saw the car, the acid splatted actually corroded the car paint.. will elllaborate more
here are some of the pics of the Spotted leopard -
some paint defect pic discovered along the way (pics Before)
paint chiped
some stains
left side rear bumper ...evidence of chewing gum stick till the rear
rear bumper scratches
some scratches before corrections
More evidence of the spots
if you see carefully u actually these spots actually look like crater on the moon
closer pics
My Rescue mission is to lose the spot on this leopard
Aim to get it corrected & restored
Menu for this ride
TBW - with an 1oz of APC to get rid of whatever that is on the surface
APC dilution 1:10 on all wheels, I am not a brightener person, dont feel comfortable to stronger acid...i am pleased with all the
Clay with Mild - Meguairs Last Touch
Dealing with OEM soft Clear coat
initial test Meguiar's #80 - Speed Glaze polish with Cutting Foam Pad on Rotary & upgraded to a more aggresive DOuble sided wool pad still not achieving the results i want, Then I call to discus the severity with the owner & advising him the details & damaged - resorting to wet sanding -
if i continue to compound, i may damaged this soft clear coat & the intense heats actually melts everything else.... he says go ahead to do the rest & i Wetsanded the whole bonnet - 200 unigrit sand paper
Meguiar's #105- Ultimate polish with double sided wool pad
and follow with Meguiar's #105 Cutting Foam Pad
Meguiar's #80 - Speed Glaze polish with Cutting Foam Pad on roof areas
Meguiar's #80 - Speed Glaze polish with Polishing Foam Pad
finishing off with Meguair's NXT2.0- Synthetic Sealant 2.0
& seal with Meguiar's Ultimate quik detailer
The glass is polish with single side wool & a special formulated glass Polish
some engine pics before
stainted water marks on the plastic well
Bonnet pics before
engine after
close up after engine detail
wheel before
APC agotating at work
wheel brush
now a clean wheel
the detail of a clean wheel
wheel arch ...before
door jam before
after & the residue is buff away with AIO Meguairs PRC D 151
pics before inside door area
during agitating
after pics
before pics
after
interior before vaccum
interior carpet is removed & clean by APC
The body shop actually advise him to get his car repainted.....and the wife came home scrubing the paint as though getting rid of BBQs grill racks
severly swirled up
the amount of swirls is unbelieveble even a silver under noon day sun is
more
TBW & wash mitt
APC aggitating
the spots resurface
Clay before
clay after
more after clay
did some extras work for him
hardest to restored ......severely stained glass
tat tatatata
after
next the actual prob area
front right side panel
closer look at these crater
Thinking of planting the national flag - the 1st arrival on Mars
initial after 1 passes of Megs # 80
after another passes of Megs # 105 - look better
another close up of another actual crater
now we are at ground zero....
as the paint was corroded by these chemical & I stop & called the ownder to discuss further corrections...I suggested wetsanding, although is not the best solution on OEM paint & he gave me the blessing to go ahead
initial testing on wet sanded area
after Meguiars M #105 passes with double sided wool
wet sanding begins
carefully sanded
after sanding
50/50 area set
and the gloss regain & stepping down to Cutting foam pad with Megs 105
stepping down to Megs M 80
the correction leveled up
Thanks to Barry Meguairs for this wonderful invention other wise my life evry very dull
gloss restored
look at the clarity & defination restored
but some sever area is too risky to go further as may chase further in to the damage
the over looking now
some day light pics
mamamia
before door handle area scrathces
now
remember before
i dun why the way up always down, u need to scratchs more to get it smooth
inorder to be built u need to be broken
before
now
close up inspection by the owner
i actually ran after the car to shoot more after pics as he is in a hurry to drive off for his dinner
some how like seeing your own children grown up & leaving home for the very 1st time
close up pics
kc, with ur standard i think almost all detailing shop in sunway can close shop...:)
im still waitin for ur reply if u r willing to detail a 3 yrs old Triton...:P
dear mr ong
thanks for yrkind words
we are just ordinary people but only attempting extra ordinary things
would love to catch up with up over a teh tarik session
would u be free to meet over today in glen maries subang area? call me 016 2209227
thanks
Wah kc, you really do a thorough detailing. The civic looks so new! Haha
Bro a long time since we chat liow
how is our little wagon doing....still havent put yr hand into her....hope to catch up with u & meet u
Cheers
dear mr ong
thanks
Cheers
Yeah kc, I barely log on these days... getting busy haha. The wagons doing good :rolleyes:, got a quick release recently nothing much else. Yeah I hope to meet up one day also, maybe get a detailing session done by you haha :biggrin:
in one of your thread, u mentioned that some scratch are too bad that it cant be removed but the best is to only improve the severe scratched look. does that mean that on direct light facing it the scratch is not visible but only when it was looked from the side angle its still visible?
like in this honda you actually perfectly removed all the spot on the hood?
thanks renxun
2 issue here
from this
to this
the scratch dent is too deep, what i managed to remove is the paint transfers but not able to restored like new (as though never happen before)
as for.. this civic thread.....pls check the pic before & after...it is at the same lighting position
we just are just detailers & not superman...like the city pic on top....nothing & no anyone can anything except, to removed those stains as the paint is still good, why waste $$$ & cos more environment issue........unless wanna to cover up some thing
I would be starting a rotary lesson soon for serious enthusiast, let me know if u r interested to learn....free bt u must practice on yrself too lah..otherwise the lesson will be forgotten
in fact i received your pm regarding the previous invitation however im from sabah. what i can do is just to observe all your photos...i camera memory card spoilt thats why im still very stuck on emailling photo of what i done for you to check out..
i did an old car once... oem paint ... wira.... it doesnt look too bad..... the paint scratch isnt too deep... but tis car had not been waxed nor polished since brand new around 15 years back ...i polished few runs... and lastly the correction i made actually reached premier layer... which made me assume the oem paint is either too thin or it has eventually got thinner over the years... and ever that since i dare not actually to "further" do correction if it happen after a few runs on rubbing compounds the scratches still exist.
bro, sorry...miss ur post earlier...but kinda busy with work this week...will try to make an appointment with u next week when im free...
no worries buddy....u too another car crazy ...glad to meet u
what did u used on yr wira & any pics?
KC, your work & outcome never fail to impress me every time. A big salute to you. Actually I have tons of question to ask you..Hahaha...I'm not such a hardcore detail person just would want to know the properly way to maintain a car paint. Preventing is always the best.
Questions:
1. I frequently heard you mention ONR. What is ONR actually? a brand or a short form? Is this some kind of a car shampoo or how do you call it?
2. I have a 10 year old car with a metallic orange bronze paint job. It's an OEM paint job and the car had never done a full repainting before. Just on the passenger side once due to an accident. Yesterday I used Meguiar's Ultimate compound after I have the car wash. Previously I would just wash the car and polish it with Meguiar's Cleaner Wax which I get from ACE.
After I used the Ultimate compound on my car, I was shocked to see the microfiber cloth was so dirty like I didn't wash the car properly. I was using hand and was able to do away some swirl marks but not 100%. Then after completing this I apply the Cleaner Wax.
Is my way of taking care the paint sufficient?
3. My rear hatch door upper part paint near the rear window had faded, colour pigments also faded. I try many ways to restore it but unsuccessful. Is the still possible way to restore it?
I have taken some pictures of my car yesterday night after I finish the car. Would like to hear you comments and suggestion about it. Maybe will post some pictures for your evaluation since I'm not from KL.
4. Swirl marks and cob web. how to prevent this if you wash the car ourselves. I never send the 206 to car wash before so I would like to know how to avoid swirls marks. Is using those normal cotton type cloth safe or better use a microfiber cloth? As of my limited knowledge swirls marks and cob webs are caused by dirt and sand sticking to the washing cloth.
5. I still can't get some swirl marks off the front bonnet with the Ultimate Compound. Any suggestion?
6. Is using a rotary pad the only way to do any swirl marks or hand also can?
7. Is Clay Bar a must every time I wash the car?
Sorry to hijack your thread and ask you so much but I'm really really interested to know more. Thank You very much
