Err... it doesn't work that way bro... The T5 TD04 15G is a MHI turbo but does not comes with MHI/DSM flanges. Because the engine exhaust port is facing the firewall, the mounting of the turbo also differs from our MHI turbo from Mitsu.
There are lots of modification needs to be done. Turbin inlet flange is different direction. The T5 Turbine outlet flange uses 3 bolts, Mitsubishi's having 4.
The compressor inlet is not a big deal. But the compressor outlet is different in terms of direction and also the flange. Mitsubishi TD0X uses flange, T5 TD0X uses hose and clip. So, they are different.
He meant the internals of the turbine. Send it to Tong Turbo Cheras. Tell him what ur expectation. Remember, be humble to Tong.
TD05, refer to above. Stated. TD05 is from mitsubishi EVO and VR4 RS(TD05 14B)
