i done service my cusco..and it work well..actually cusco cannot service..but need some modification to be like tein..and it can service after that..so..4 more information..can cal me 016-2345389 ( mawi )
asking..why some abs bought from hcut after install to our seg the front will higher than rear..mine kayaba buzz spec soft hard..front 2 finger..rear 1 finger..is that due to mine are ori 4afe eng..how about if i put 20v eng it will be 1 finger front n rear..
Top Perfect can set the rebound and damping rate according to your needs. I last service my GAB soft/hard damper at their place. They managed to retain the soft/hard feature.
Heee...all the old timer prefer Top Perfect...Pendekar Zul also sent his HWL there...(for sure laaa...HWL made by Top Perfect ...heee)
but abit curious...since gas absorber is not serviceable...mostly...don't make mostly, let say all of the service company will change to Oil type suspension...am I correct ?
Ok here's the tricky question ...will the characteristic of gas absorber will be the same after they changed it ?
cuz i like the sound of gas absorber, when ever "it come out and play"...
"syioookk syyiookk" heeee...
so now im put 1 inc rubber to ngam wif front..if i take out da rubber..so it will lower 1 finger from front..than load wif pasenger than become sampan..
