kembara piston ;)
Dude i know but what is slip dude huhu that i want to know huhu
kembara piston ;)
4g18 piston cannot fit inside 4g13 block... even if u bore the block till it can fit, it will not match the stroke of ur 4g13 crankshaft... 4g18 pistons need to be used with the crankshaft as well in 4g15....dude for 4g13 what piston can be fit? Have read some in net that they can put 4g18 piston inside but they put slip can anyone explain to me? Hehe and what are slip? Can't bout that bro sky(taiko) can convert 4g13 into twin cam? I don't wan change block la just to increase the displacement hehe anyone?![]()
if u wanna maintain 4g13 block, jz get oversized piston... maddriver has done a 1.4L 4g13 engine before...
oversized 4g13 pistons, mayb... not sure... it's maddriver's secret recipe...ooo, so 1.4l piston, is from what engine?
macha, open eyes wide wide and read ok... i mean 4g18 BxS not same with 4g13/4g15 BxS...Check out the specs first dude... B X S of both engine
4G13 B71mm X S82mm
4G15 B75.5mm X S82mm
What do you mean by the not matching stroke. They share the same shortblock. Just different after cast machining.
The CTC of the cylinder are the same. Which is why the intake manifold can be shared.
sifu has sipoken....no point using 1.3 block, just go plonk in the whole blardy 1.5 block and settled.
1.3 block unable to fit in those pistons, it will be dangerous cos its near to water hole.
just buy an extra 1.5 block, take out everything then plonk in a 4g18 (waja) crankshaft and pistons into your 1.5 block. you'll have good low end till top and your displacement will be 1.6.
fitting in the crankshaft is already stroke, comp will be higher but just used few head gaskets to be sure.
some 1.5 blocks no nid to bore (to fit in waja pistons) but some need to bore, if bore also will be very minimal.
i've used kembara pistons before, only about less then 20% improvement and the pistons is only about 0.5cm taller then the usual standard pistons.
there are many oversized pistons available for 1series, do search around. many has done it before and there is no reliability issue at all, using it for daily drives and sometimes spirited drives.
visit www.4g1series.tk for more info about 4g1series engines.
some car manufacturers only design the car/engine to be that capable... this gives alot more room for improvement for car tuning industry to grow....This topic is going way beyond street performance enhancing . If u guys can think of so much options, then engineers would just stop designing & building engines and so pass down the job for u guys.![]()
True every Non performance engines are purpose build for reliability & etc ......
Every part of the engine is measured and calculated in such a way that it can to last for years. But hey, we are smart and think of ways to improve performance n stuff as a result shorter engine life which needs you to waste money on repairing or whole motor replacement.
For example, as fstrader said, 4G15 engine swap in kembara piston with no reliability issues that is good. But if u suggested 4G13 block this n that option, thats just too much. U just don't understand the kind of stress n strain the internals encountered and how much pressure would the kind of material on the parts can withstand......
U guys are very very good in mix n matching with parts n parts , i admit i'm not as good sifu skywalker and others due i'm still a learning engineer. I'm happy to happy this tread as " Way of improving performance engine" rather than teaching ppl to improve such non potential 4G13/5 engines
there are many ways to improve pressure, not neccesary change piston. skimm engine head is a way, do large port n polish and switch to weber/delorto also a way. not neccesary so mafan touch engine internal.
hapeace, what u can do is, safe up n buy a 4g15 injection kit, apply on your engine (like sifu sky), then find this guy khguan and customake double intake to improve your engine torque and respond. and change highcam.
I believe what you do above, should give you the power somewhat like 4g15. If you want more power, just converto to efi + turbo + emanage. And you can have a 4g13 perform somewhat like 1600cc sohc. But you still lose to stock 1600c dohc. I am driving both turbo n na car. Turbo is not always win coz the lag.
So, as everyone shared, its not reli worth to do so much on a 4g13 with carburetor. Is a waste of money n time. Coz a simple 4g15 block swap already win all the mod i mentioned above. If want to mod, mod wisely lor.....
In my point of view, 4g15 is a good touge engine, modify n focus on low end torque. A guy in zth with black wira on 4g15 tuned, went to GRA last time and got 2nd place, 1st place was a lotus elise. but 4g13......reli cannot ler my friend :)
:hmmmm::hmmmm:
