- Joined
- Jul 10, 2004
- Messages
- 987
- Points
- 3,028
The increase is negligible, you could sell away your emanage 2nd hand. Sometimes to gain power its trial and error. The money you can fund towards a high cam. Or if you have alot of money, you could just wait till you get your hi cam. Furthermore I thought you said your emanage only run on ignition harness? No injector harness? So how come you said can tune your air fuel and make it more save petrol?
High cam for 20v costs more than 2.5k..
For E-manage,no need to have injector harness to adjust the fuel,the injector harness is only for sube injector,or want to add more fuel where the airflow adjustment map cannot cater for.For those running e-manage,its good to have ignition harness,because when you add fuel,timing will retard,when lean out fuel,timing will advance,an adjustment to the timing is needed.
