i hate u all la... when i play ae time, i look for such thing for such price, dun have. now when i dun play anymore.. all these thing pop out... i HATE u all.... whahahahaha
hihi, i m interested on ur pipe. how much lar? :-) i need to know how you measure the 2.38"?
I also having a whole set of levin piping, but i measure, it is not 2.38", maybe i don't know how to use or read those engineering ruler.
this is tough question bro... i try to answer.. if wrong dun shoot me...
1st.. the levin piping u need to find a portion tat completely round in order to get perfect diameter. some of our levin piping pipe is not completely round.. some portion is eclipse shape.. pls confirm this be4 do measuring...
about 2.38" .. actually is called 2 3/8".. which is not same 2.38"...
in term on metric measure will be more easy to u to understand..
1" = 25.4 mm
means 2 3/8" = ( 2 3/8)" x 25.4mm
= 60.325mm (so.. u can easy check by using normal ruler also ...)
hope u can understand this calculation and use correctly on tat vernier... thank
After doing some research, I understand that the sluggish feel (weak throttle response) of altezza is caused by the heavy dual mass flywheel which weighs about 12kg.
hi all.i am planning to buy a rim...for my ek 4door.got 1set is mugen rnr black colour 6.5jj n the other set is p1racing grey colour 7jj.dun know want to pick up which set price r same...any advice?thanks
Hi all,
I just bought r32 & plan to swap with the rb26dett. What I know the engine mounting re direct bolt on but have to look for the rb25det trans & axle. My quetion how to modify the rb26 oil pan? Any other parts...
