i am a toyota LE owner..from my point of view...use back the original servo...really..its still the best..you can fit those ae101..i did..but i swap it back to original LE...in fact, the original LE is just pnp...easily pulled out and in...by fitting the ae101, you need to ketuk the side of the servo abit to fit it in...worst is double layer...super tight to fit into LE...if you are running on ae80 to ae92 brakes..use back ori is also enough de..there is braking difference like if you change from drums to disk..its the same..only look cool and better heat dissapation thats all...bro fgt is right, just buy a new servo and use back the old pump..depends on which is spoilt...
