Hello all, I'm currently using a GSR Turbo with TD05H E3 turbo. Using E-Manage blue for tuning and running at 1.1 boost. I'm using E3 fuel injectors 510cc. Blitz boost controller.
I thougt of upgrading to higher topspeed. Curently I'm getting 210kh/h @ 7,000 rpm on stock GSR gear box. What's all the sifu's advice on this? Should I go for E3 gearbox? Or E1..E2 gearbox? Or just chg final gear ratio and add LSD?
What's the recommended boost? If I boost 1.5 bar, should I change the pistons and conrod...etc? What's the best brand to rojak it?
I'm using E3 2 pot front brakes and E3 single pot rear brakes. With bentax titanium king brake pads. But I feel it dosen't have enough brake power... What should I do? Change better brake pads? Or 4 pot?
:hmmmm:
:hmmmm:
anyway, happy modding turbo .......
Do I need much modification if chg to mivec head?
oil cooler screw is not tight although fully screwed and put in seal tape..... leaking.. o0o local jasma...... even i go potong shop find a pajero oil cooler and custom hose fitting and screw is better and cheaper then it, cooler than tat also..... if drag i recomment u find mivec gearbox (i dunno wat difference between gen1 and gen 2 mivec gearbox but i currently using gen 2 mivec gearbox), gear quite close ratio , i can hear from sound, gt mivec gearbox originally come with lsd, c ur luck, i using mivec gen 2 (terbalik) in my wira chasis
