- Joined
- Jan 19, 2007
- Messages
- 26
- Points
- 1,503
Need advice from all sifus and if anyone ever had the same problem as mine. I drive 2002 Caldina GT4.Now days I found my GT4 very hard to start. Even worse during morning..I have to crank about 6 times (every crank ending with switch off all, pull key out, put back key in, ON ignition and crank again) to start the engine..if lucky after start, the engine idle like normal (no prob)..but sometimes (normally morning time) even after engine start, it die off again after few second and I have to crank again...I've been to few workshop and check..some mechanic says its because my plug is wet..(I look at it, only little bit wet by engine oil..too little to cause the prob.Even last time when my car was ok, my plug are always a little bit wet and only one plug..the other 3 are all OK..I use TRD spark plug).So I dont think its bcos of the spark plug. Another mechanic suggest to change the fuel pump (Caldina GT4 feul pump=RM1300!!). Maybe the motor is not strong enough to pump the feul from the tank to engine..once the car can start..the feul pump start pumping like normal (although i found it weird ;))
some other mechanic told me maybe its because of the timing valve..maybe a little bit loose (i dunno where is the timing valve honestly..i just angguk ;D).
One more thing i find weird is whenever my car is not moving and the engine is ON and the idle timing was OK, the timing will drop suddenly everytime I turn my steering wheel to right or left.Is like something that the shaft touch everytime it move that make the timing go low (although I dunno what it is)
btw, I just service the throtle body and spark plug, so I dont think its because of that.
Anybody care to share their experiance/opinion or good workshop for GT4 are most welcome because currently I dont know what cause the problem..and living like hell everytime want to start my car. Just waiting for the moment my car die off at the traffic light (touch wood)..
Thanks all in advance...appreciate it
