Hi, today i contact my foreman to quote me for a major service for my SGTi:
MMC timing belt set: 580
valve oil seal: 98
plug O ring set: 152
fan belt: 50
alternator belt: 30
air cond bearing set: 98
water pump: 165
Hi Rev semi-syn lub + oil filter: 104
labor: 120
Daikin clutch set: 420
clutch oil seal: 55
drive shaft oil seal: 36
clutch cover: 38
transmission oil: 35
drive shaft cover: 25
drive shaft butteroil: 20
labor: 150
Plug cable: 205
clutch oil seal: 18
coolant: 35
radiator service: 95
engine cleaning: 100
change cross bar under the air cond bearing: 220
Total Damage: RM2800
the price is reasonable ?
valve oil seal: 98
fan belt: 50
alternator belt: 30
water pump: 165
labor: 120
clutch oil seal: 55
clutch cover: 38
labor: 150
Plug cable: 205
clutch oil seal: 18
coolant: 35
