errr, I got spare 2 vr4 balance shaft :wavey:
pm me if u want..
pm me if u want..
of cos lerrrrr i posted n first post its a machine job jer, bt one of our fren already chopped his balanceshaft muhahaha, u know him :P , he is looking for a machined one now, stock vr4 balanceshafts are nt easy to find unless someone broke his engine
Err....i had removed my balancer shaft belting.Im using it for around 5 years.No side effect except engine got slight vibrate n the engine feel more response.
i got few stock balance shaft sitting at home :) evo n vr4 the same lerr.. u want kerr??keke
chopped balance shaft no good but still better then just taking out the balance shaft belt without removing or chopping the balance shaft kekekekeekekeke
balance shaft belt removed alone still practices worldwide including kampung and dsmtuners hehehe
no issues reported yet :P all running well
wat!!! omg!!! did you change yr oil pump, crankshaft & oil cooler when yr rod bearings toast?
james, i replaced with evo block but it lasted for a while only...piston ring gave way...then i rebuild my vr4 block...vr4 block done but havent install yet :proud:
i would say burnt rod/main bearing wouldnt effect balance shaft unless the debris flow through the oil and get to the shaft...its good to ask than to learn the hard way, we are in forum to ask and answer...hehethanks for sharing spuzzle as 1 of my friend recently also rebuilted his evo 6 due to rod bearing problem...but after he took out the balance shaft his mech and him found out its hard to put in back in place...Dont why? So scary? Btw,will a burnt rod or main bearings affect the balance shaft?
Sorry for asking much...
Btw,it will be very crucial to change yr OIL COOLER yaa for the sake of long term durability...
last time i couldnt find vr4 internals to replace my crank, oil pump and balance shaft until i bought a complete engine...by the way why dint see u online msn for so long?told u last time already,better rebuild your vr4 block,evo stock piston ring and piston and con rod like tofu fa man,whatever u gain the real exp,good luck
I wonder if anyone out here can advise on the...
