guys...really need yr advise here.
my idling not stable.its stuck at about 2k rpm(warm engine) and if i set the idle down lower, the engine will idle like a hi-cam. auto-choke and throttle body aredy changed 3 units still cant idle normally. ori TB also cleaned and all vaccum hoses checked - no leaks. when he close the auto-choke(air in-outlet) then idle will go down to about 1.1k but when on aircon will drop to about 200rpm(engine at normal running temp) if cold start on aircon, engine will straight die off. tried retarding the dizzy to the max, then idle(on n off aircon) will be normal at about 900rpm. problem is if retard to the max, then totally no power. anybody has any idea whats the problem? before did the porting n top overhaul never had this problem...issit cos aredy done porting thats y A/F setting all gone? another question...is it normal to have a little hissing sound at idle after porting? something like air being sucked type of sound...
