Coated by Dynatech
WE ARE OFFICIALLY OPEN AT SHAH ALAM!
Address:
Coated by Dynatech,
No.22A, Jalan TP 7/2
UEP Light Industrial Park
40400 Shah Alam
Selangor
We have upload our location in our blog or just search Coated by Dynatech in googlemap.
Good news!! Our big oven (3wx3lx6h feet) is now ready. It can fit all 6 cylinder engine part and rims from 14inch until 20inch and above 8-)
We do powder coating for a wide range of applications. Including Motorsports, Racing, Show Cars, Motorcycles etc. We try to provide as much color selection as we can to you pimp your ride. Example of part you can powder coat such as valve cover, fuel rail, rims, turbo compressor housing and so much more (as long that part fit in our oven )
Why powder coating? Powder Coating can withstand higher temperature than normal paint. So you part color which is powder coated can last longer in your engine bay. Powder Coating also not easy to scratch and peel off like normal paint after use for long time.
See our picture for example.
Please contact us for color selection or search for Coated By Dynatech in Facebook for sample of color
Contact:
Shidie (013-2048859)
Ariff (012-6212352)
FAQ
Q: Do powder coating provide a rough finish surface only?A: No, the rough finish is the type of powder use (wrinkle / crinkle / texture / vein), it also does provide a super smooth finish and glossy finish.
Q: What clear coat do you use for the top coat?A: We use only powder clear coat, we have in stock crystal clear super durable gloss clear and glass clear. Normal clear paint will not bond with powder.
Q: Why does your price for coating valve cover more pricey compare to others who provide wrinkle paint?A: We used powder, not the normal paint, and we only ordered a high quality of powder to satisfy your need. Wrinkle paint also can be done using normal paint. Powder can hold a medium temperature range so your powder can lasted. Also it hard to scratch and hard to peel off. The preparation before powder coating parts also different from normal paint.
Q: Can powder coat applies to plastic part?A: No, because in order to finish the powder coating process, the powder is heated in oven to 400F in order for powder to be cure. This will make your plastic thingy melt.
Q: How much to powder coat a rim?A: Frankly speaking it will be expensive since it will use a lot of powder. But of course if u willing to pay for it, we are here to do it for you! We also have to special order powder for you and it will take 2-3 weeks to arrive here (we import from oversea) unless we have a lot of that specific color in our stock. Customer need to put down 50% deposit. Once the powder arrived, we will contact you to your rims. Usually it will take 4-1 week to finish your rims. Contact us for more details.
Q: Color that I want not in your stock?A. We can special order color for you but that color must be available in our supplier stock. We also need 2-3 weeks for powder to arrive here. Please contact us and we're glad to help you to find your color.
Q: I'm not from KL, can I post my stuff?A: Yes, contact us and we will give u, our full address. Usually need 1-3 days (depending on size – for comparison, valve cover usually takes 1-2 days) to powder coat your part, not including delivery time.
Address:
Coated by Dynatech,
40400 Shah Alam
Selangor
Contact:
Ariff (012-6212352)
FAQ
