Conrod or conrod bearing gave way, then it hits the block la.. making a hole...
Cause dunno yet... simply a failed conrod or its bearing, or even a failed oil pump causing low oil pressure to the required bits...
Do you have a anti g force baffle oil pan? if you don't, thats your main cause of oil pressure loss, hence blown engine.
