wahhh new waja got it ah????
dammm then better buy already somewhere down the road evo x halfcut will be cmin to stores near us
then the transformation will be complete :top:
Just wiring..since Savvy AMT gear shift using robotic arm(some sort of electronic). The pal just put 4 switches on his original stereng, shift up, down, neutral & reverse. its look not so cool but its function greatly just like paddle shift. for viewing, u can register to www.savoc.net in DIY part. really proud to be savvy owner!:proud:
hi guys... i got vios with turbo kit,just wanna know how to see d boost meter reading properly?i mean,sometimes when i hit on d throttle the gauge indicate 0.6 or 0.7 bar... but during higher rpm when i hit...
i intend to install another RPM sensor for my car. the easiest way is to install the sensor that reads engine timing from the alternator. do you know where can i get such device. i want the output to produce analog...
