Hi all,
I'm Kenny of Kegani Autotech. was invited by ysl to join in this topic. I hope to share some information with you guys about my impression on the Z and when it is on track.
the Z certainly has good handling characteristics, being a rear wheel drive car has the advantage of early acceleration, handling feedback is good.
The stock transmission ratio apparently was pretty match for Sepang track, yet, can be further fine tune to trim down lap times. The v6 engine produce good torque and acceleration, important for turn exit, despite the car weight.
I've done a corner weight on the car before, the front : rear ratio was 55:45, and cross weight was at 48+. Further setup can achieve a cross weight of 50/50.
however, it's a mean 1,500kg heavy car.
The Nismo380RS with lightweight cf body parts weight 1,370kg, trust that a fully stripped Z super time attack car can easily achieve 1300kg.
paired up with a target 380ps engine, giving a 3.38 power to weight ratio, that is slightly higher than a Porsche 997 GT3. (referred to MME2010 GT4 list).
by figures, it's seems be a competitive race car.
On track impression, the rear wheel drives really turns the driver on at all time. Having a full lock LSD installed makes the car very 'tail happy', but with some damper adjustment will minimize oversteering at turn exit.
Good straight line speed + 1,500kg car = braking point gotta be early.
With a good big brake kit installed, you should be able to do your braking at 120m.
something like 355mm rotor and a 6pot brake kit will be ideal.
It is a "driver's
challenging car" and I must highlight that the engine and exhaust sounds really unforgetable...
