safc 5 button on L2
todamax
hi all..does anyone know how to set the car select and type select at the back of the safc 5 button for mira L2?:hmmmm: tq
---------- Post added at 12:56 PM ---------- 6 hour anti-bump limit - Previous post was at 11:32 AM ----------
anyone???
hi bro..i didn't manage to get the tach signal from the N- pin...i tap the rpm signal from the IG pin..wonder y the N- didn't produce the tach signal..do u think the ignition system got any problem?and what is the IG stand for?is it ignition feedback?tq
Bro E-Tech thanks very much for wiring diagram.
todamax I had the same problem and had to do the same thing that you did, since it's working fine,i'll jus stick to that.
so where did u tap the rpm signal?
is it same the car select and type for L902s Jb-det 4 piston with L2 or L5? cuz my 5 button the rpm (red lamp) not working...:hmmmm: & can or not to modify the safc to remove the boost cut? help me..
