hehe.. i tot the amazing type r surbo thing gona come out again.. hahaha
Good idea, but the downside is that I don't think ur fan can go that fast to improve the air flow intake. Check the RPM of the fan. Another matter for you to think about is that the RPM of the fan would be constant regardless of the RPM of the engine. So at low engine RPM, the fan might have higher RPM forcing air to flow to the intake manifold, this would screw up your Air Flow Sensor (AFS) reading, fueling would be over rich coz your engine would think that there is a lot of air flowing into the engine so engine would not run smooth. Then say at high engine RPM, your fan's RPM might be slower, so instead of forcing more air into the intake, the fan would now cause more resistance to the air intake...Originally posted by raymond@Mar 4 2005, 11:55
Anybody trying of a 12 CM CPU casing fan with DC 12 volt 0.40A on a air filter.
Mod the fan in it, pull a cable and plug to the cigaratte lighter port.
then the AIR burning shall improvemore as the AIr intake much faster.
shall the K&n Filter work like this ?
:D a STOCK FILTER will do actually.
:lol: wan a try? i trying ...
can i know how much this fan cost???Originally posted by drexchan@Mar 4 2005, 13:03
it will be good if you can source one of this:
http://www.nidec.com/va450dc/va450dc.gif
at http://www.nidec.com/va450dc/va450dc.htm
220 CFM, 12VDC, 3.3A, OT -10/+70 deg C.
Originally posted by trex92+Mar 6 2005, 13:08 -->
QUOTE (trex92 @ Mar 6 2005, 13:08 ) --QuoteBegin-raymond
@Mar 4 2005, 11:55
Good idea, but the downside is that I don't think ur fan can go that fast to improve the air flow intake. Check the RPM of the fan. Another matter for you to think about is that the RPM of the fan would be constant regardless of the RPM of the engine. So at low engine RPM, the fan might have higher RPM forcing air to flow to the intake manifold, this would screw up your Air Flow Sensor (AFS) reading, fueling would be over rich coz your engine would think that there is a lot of air flowing into the engine so engine would not run smooth. Then say at high engine RPM, your fan's RPM might be slower, so instead of forcing more air into the intake, the fan would now cause more resistance to the air intake... [/b][/quote] i dun think so. A supercharger specialist/experienced user can tell you that your statements were wrong. |
e-RAM, e-supercharger, e-turbocharger.... all are NOT NEW. And they don't provide your clean burning. Haiyoh.. <_<Originally posted by raymond@Mar 7 2005, 13:01
What i wan to tell in this thread is... new stuff.
is supercharge blower.
For supercharger, can add on extra,. with bolt on. and it cost like mad.
Air charger is just to make ur burning cleaning, somehow play for fun if u wan to waste some fuel, then ON it.
Originally posted by drexchan+Mar 7 2005, 10:34 -->
QUOTE (drexchan @ Mar 7 2005, 10:34 ) Originally posted by trex92@Mar 6 2005, 13:08
@Mar 4 2005, 11:55
i dun think so. A supercharger specialist/experienced user can tell you that your statements were wrong. [/b][/quote] whict part of my statement...? :P |
Okie, maybe i should try to explain more on what I said. Imagine this scenario, car is at idle at 800rpm say. So now, let's say we are using a CPU fan which the RPM of the fan is constant and that the RPM of the fan is higher and is sucking more air than is required by the engine at 800rpm. The air that is sucked by the CPU fan is connected to the Air Flow Sensor (AFS) and then to the air filter. When the fan sucks more air than is required by the engine it goes thru the AFS, the ECU is bluffed into thinking that the engine is taking in more air than it actually is (same concept as Apexi's S-AFC, but then again AFC settings can be adjusted). Hence, the ECU would increase the fueling ratio. This increase of fueling ratio would cause an over rich mixture and cause improper engine combustion (too much fuel with too little air) and premature engine detonation might result.Originally posted by drexchan@Mar 7 2005, 10:34
opppss... just saw ur this reply before i put my reply up above... :DOriginally posted by drexchan@Mar 7 2005, 17:19
I didn't say that you were wrong.. i mean trex92 (hmmm drex lawan trex.. haha!!)
See...
it's not the matter of fan RPM, it's the flow rate, measure in liter/minute or cubic feet/minute. 2 fans with the same RPM can have different flow rate, due to the number and the design of the blades.
Engine intake (air) flow rate is based on the engine RPM and the volumetric efficiency (V.E.), not the flow-rate the fan/e-supercharger can provide. The fan/e-supercharger do provide high flow rate if stand alone. But in the intake hose, they will just increase the V.E. If powerfull enough, compressed the air in the intake system (V.E. > 100%).
For example, engine needs 100 CFM, fan spins at 2700 rpm, which when it's stand alone, can provide 220CFM, the engine will only take slighly higher than 100 CFM... maybe 10% higher, and increases the V.E. to 95% (if, let say the stock intake provide 85% of V.E.).
About the sensor signalling. See, the fan/e-supercharge is installed before the filter element, and the MAF is located behind the filter element. The MAF measures only what the engine takes. Futhermore, most of the car is now running on MAP sensor (even further behind, in the intake manifold) instead of MAF sensor. Like wise, higher engine intake, higher pressure, higher reading, more fuel).
So, your engine take slightly more air because the V.E. has been improved, MAF/MAP sensor measures slightly higher flow rate (or manifold absolute pressure), as high as what the engine swallowed, injectors inject slightly more fuel because the ECU told them so, you will get an accurate mixture, at bigger volume, combusted in a same cylinder.. You get more power.
Not correct also if your fan can provide a higher flow-rate than the engine intake at red-line revolution. It'll not block the flow.
It's not a matter of "can work or not", it's a matter of "right material, right design and durability. If the fan concept doesn't work, a belt-driven supercharger will not work as well. But why it works?
p/s: Dun ask me what is V.E., MAP, MAF and the theories behind the story of "how EFI works). Read up.
Yes, i understand your point with with CFM. But as what you said, engine needs 100 CFM, and the fans provides 220 CFM so the engine gets slightly higher than 100 CFM. But the ECU would think that the engine is taking 220CFM as the intake air passes thru the AFS and AFS reading is 220CFM, right? So the ECU would inject in fuel for 220CFM of air rite? The AFS is not just for show remember? regardless of where you put the fan, as long as the air that the fan sucks passes thru the AFS the AFS measures how much air intake is flowed to the engine and tells the ECU that. The ECU would then decide much petrol to inject. Like my above reply, think in the sense of Apexi's S-AFC.
Anyone have a good all-in-one centre to recommend?
