Wise move. Halfcut coilovers are a gamble. If you get a good one you won't know how long they'll last and where to service. Spend some good money on a decent BC or HWL and you'll have better peace of mind.
Sigh. Try handling 140whp first then tell me how you'll want to handle 250bhp. Btw, if you're going to go so high powered, you'll need to worry about a completely new set of things. Torque steer, wheel spin, drive shafts that can take that power, gearbox, etc. Expect to pay through your nose for custom made reinforced parts.
And what exactly is "cap ayam" tuned? Is there such a thing? A badly tuned car will probably break something. A poorly tuned car probably will not fully bring out the power of the car. A decent tune would probably be "safe" so nothing blows up. So what's cap ayam?
Depends on what you want to do. Top or full overhaul? And if full depends on what you want done? If it's already out, you might as well spend on getting mods done there and then. Taking it out again and again will cost more than necessary. Things like oversized pistons, head skimming, crankshaft, bearings, port and polish, etc. So all depends on what you want done. Cost can range from RM2k to RM9k.
Sigh. You really don't get it. VDO is a lot smarter than the ancient MMC. The only good thing about MMC is it's got more aftermarket support in terms of reflashing and all. But why bother with flashing it when VDO can just adapt? Unless you mod over the map limitations, it'll adapt to most NA mods. With everything I did, I kept the VDO until I finally got my hands on a piggyback. Installed it and had it tuned, improvement of only 5-8whp. Meaning the VDO was more than capable of handling all my mods.
Why is that bad?
Huh... you need mechanical mods more than you need those things.
Everything wasn't designed for that sort of power. Oil seals, gaskets and all will have a shorter lifespan. You'll probably have heat issues on hot days too unless you upgrade the whole cooling system. This is for BOT.
And don't expect BOT to give you 250bhp. Probably no more than 110-130bhp from complete stock parts with low boost.
Properly means you do everything properly. Not half assed. BOT in my personal opinion is half assed. Stock internals and stock everything with a BOT kit is wreckless imho. Personal opinion.
Dude, 0.5bar boost will last you 2 weeks. After that you'll want more. Then slowly increase a bit a bit then one day boom... piston decides to take a vacation. Spend another few thousand fixing everything again. Why bother la? Do it right the first time and spend more time enjoying the car, not spending more time in the workshop.
Well said izso. you mod you want to enjoy your mod not spending so many time in a workshop. For me I enjoy my car, its decent and worry free. If you want more powwer like 250hp better start saving money and buy a real 250bhp. Because your current car is also a day to day use car. power craving is never ending lust.hehe
