4G93p engine knocking sound
pje
I need some advise from any 4g93p sifu..
My engine produce knocking sound 'ketak,ketak,ketak...'non stop. Before this, the sound just a while only, a few second after engine started. Are they tappet or what?
For your info, i used Eneos semi syinthetic engine oil.
gues probably is tappet...
i'm having the same problem..just don bothered bout it...it cost rm45 per unit..so 16 X 45 = RM720
wait til it really serious only i wil change all...hehe
Use oil treatment. If still da same, ur tappet force u to service. A bit pricey la, but, what to do...?
maybe engine oil that coming to the head not enough..try service ur head n hydraulic valve..check your engine oil regularly...
check your extractor oso,bro..............mayb gt leaking....
Another problem came, RPM suddently high when the gear in free/N and become normal when I shift the gear to D, I thought my peggy back ECU kong already but after i change to standard ECU, the RPM is high and down repeatly, Ahhhhh tension!!!!!!!!!!! my TB also kong.....
