4G93T turbo prob
bikerz
i haven't start my car for 1 week. so when i start, i drive until turbo start to boost the engine make noise like glok3x and the CEL is on, ... then i park back my car and drive another car.
Is it because the engine is cold?
try this , on idle, dont put gear, rev the car, if got glok glok glok
check if ur engine oil enuff , if not enuff, faster top up n see if got oil leaks
if oil all got, but glok glok glok , sorry to say, bye bye engine , it could be a conrod bearing wear
do i need to reset so that the CEL off? if yes, which fuse to plug out?
but that CEL appear when the glok3x sound start?
got glokx3 only CEL on ... so check ur glok3 1st b4 settling the cel
Bump: got glokx3 only CEL on ... so check ur glok3 1st b4 settling the cel
check ur ecu, and the glok3 sound is just the sound of the cam pushing the valve.
yes, the glok3x sound settle, but CEL doesnt turn off (T_T)
bikerz..take my engine..
give me ur gtt..kekeke...
jk only...:biggrin::biggrin:
bro, try this, call someone to help u press the brake then u `cabut` the negatif battery `kepala`, wait for 10 minutes, then press back the brake and put back the negatif `kepala` back on.
hehe, settle, CEL bcoz of MAF sensor unplug. plug in, everything settle
suspected that actually.... But didn;t wanna say out cause normally that should be the first thing to see...
