Kyogezsho said:i need more advice ..
anyone ?
kyheng said:So what type of glue you are using? Is it silicone glue? You are right, if do the box ownself can get a good one, but buy is... That's i say if buy the box, better buy ported one, less headache and cheaper. If I buy a sealed one, maybe after sometime I have to take out the sub and reglue the whole box. Nowadyas acc shops only want fast money. So they will say ported better than sealed.
Kyogezsho said:hmm ... so wat kind of box shall i get for a 12inch woofer?
i wan tahan lasak ...
quite good sound
is there someting like dat?
kyheng said:because of you this topic is totally tilted by you....
kyheng said:Ported won't leak so easy as there is a port or hole and the pressure will be more balance. Ported box is more boomier, bu will not leak so easy.
