Abt.ToyotaCelica.Need HELP!
top up the i/c tank. the white plastic bottle is just an overflow reservoir. with the i/c water pump running wild, you will see a water swirl under the i/c radiator cap. if u don't see that, rev the engine a lil', mayb thermostate still sleeping. hotwire the pump u will have constant i/c coolant flow, works fine for me for 3yrs+.
jahd, u try dump ur clutch few times with handbrake on, see the mount makes sound or not :lol:
hmm
when i took off the cap there's water in the IC. maybe today try rev and top up and see wat happen....
the mount make no sound............. very quiet mount.. eeerie.. hehehe but wait around 15 mins of driving then this bugger make the most F**KIN irritating sound.
make sure the water swirls for a healthy water pump check. can top until it overflow. :D
the mount rubber harden oredi innit ? spray wd40 ? apply silicon ?
kevinc,
my sillycar gear 1 and 2 last time very tight one coz im using shortshift but now one and 2 is darn loose like normal car, but the the rest of the gears like normal? how come do u know? haha
u devirginised it's 1st & 2nd time oledi laa :lol: i mean 1st & 2nd gear
:rolleyes: is your half cut come with the gear shift set? do yuo want to sell? and the lower arm front......
What the best muffler for toyota celica ??? to reduce the sound .. now it's too loud ..plan to change the muffler?? what the best brand muffler good in market.. but I want to reduce the sound and good for air flow circulation...
any idea??
which one do u suggest ??
any idea??
wat muffler u r using now??? im using apexi muffler but thinking to change it coz its too loud also... :)
