Adaptronic Standalone ecu for AE111
GT20v
What's so special about the Adaptronic?
Because the amount of fuel required by engines differs under different conditions (eg throttle position) and between different engines, the ECU must be tuned for the particular engine. This process must be repeated when other modifications to the engine are made. This can often take a lot of time to perform, even for an experienced tuner, because the tuner has to manually adjust the fuel mixture on the ECU, and retest the engine, for hundreds of different conditions. Time on a dynamometer can be quite expensive, leading to a very expensive engine modification.
There is another method, which is where the ECU automatically adjusts the mixture strength to the user's specification. This greatly speeds up the tuning procedure. This technology has been employed by MoTec (Quick Lambda) and Autronic (Autotune), however their use appears limited to tuning on a dynamometer.
The Adaptronic has been designed from the ground up to run continuously in adaptive mode. This means that after performing changes such as a new exhaust system, the user merely needs to continue to drive the car on the street, and the ECU will automatically adapt to the changes made.
This makes life easier for vehicle modifiers and the end user, while encouraging responsible car tuning, leading to less pollution from modified cars generally.
More reading here http://www.adaptronic.com.au/index.php
Adaptronic e420b AE111 Blacktop 20v.
This ecu only suit 4age Blacktop 20v. The ecu was originally done plug & play.
meaning no wiring need to be mod. just plug and tune and rev!
All the software,base map,detail map can be found and downloaded FOC from the site above.
Please not that this is a FULL standalone ecu not a piggyback typ like Emanage blue/ultimate/Unichip.
Set rev cut,speed cut/ignition what ever your heart desire!
Reluctant sales..but need money :bawling:
Please do drop me a pm or call 012 3847369 if you are interested.
For now the price set at Rm2200.Call to discuss further. Picture will be uploaded upon request.
Check out the site.Study the site and download the manual and see what it can do.
Here is something to ponder
http://www.adaptronic.com.au/comp.php
and buy the ecu that you UNDERSTAND the language instead hehehehhehe :proud::proud:
UPDATED:
I have flashed the ecu with the latest firmware and downloaded the newest tuning software for your convenience. Included also a couple of base map for blacktop to start the car and get it running. Just need some tuning and its all done!.
Mucho Gracias!:adore:
even in english, i also cannot understand how to tune an ecu.
good luck in your sale sifoo
at least 1 issue/difficulties already kawtim..
instead of...."eh apa ini word set aa?"
hehehhehh
age of item bro?
pm me the best price pls?
I bought it new actually.
age around 2years.
pm sent
yeah good stuff!
sell that emanage blue and get this fully adjustable ecu....
cheaper than emanage ultimate which is still a piggyback......:adore:
hi there, can it be use on a 20v bt engine with turbo kit?? where is your location??
of coz bro!
this is a standalone unit..it doesnt matter what kind of mod u done...
only thing matter is the tuning...
located in KL.
I suggest you go the site above and download the tuning software..
take it alook and try play with it.Load it with the 20v base map that can be found in the site...
you will understand how good is this ecu..
you know who to tune? what does the ecu comes with??
ecu + software cd..anything else can be downloaded from site.
tuner you can go to ur fav tuner...or can contact friend of mine....
is it easy to tune? can DIY ah?
emmmm if you know how and have the proper tool..then yeah can diy..
if not then better let the pro do it....
get a tuner from kelantan aaaa
localStorage.removeItem('xenFHideSidebar'); } }); }); $(document).ready(function () { 'use strict'; $('#gece-modu').on('click', function (e) { e.preventDefault(); $(document.documentElement).toggleClass('gece-modu'); if ($(document.documentElement).hasClass('gece-modu')) { localStorage.setItem('xenFDarkMode', true); $("meta[name='theme-color']").attr("content","#090909"); } else { localStorage.removeItem('xenFDarkMode'); $("meta[name='theme-color']").attr("content","#202020"); } }); }); $(document).ready(function () { 'use strict'; var aktifYukseklik, currentScrollTop = 0, header = $('#xenF-header'); $(window).scroll(function () { var scrollYukseklik = $(window).scrollTop(); var headerYukseklik = header.height(); currentScrollTop = scrollYukseklik; if (aktifYukseklik < currentScrollTop && scrollYukseklik > headerYukseklik + headerYukseklik) { header.addClass('slideUp'); } else if (aktifYukseklik > currentScrollTop && !(scrollYukseklik <= headerYukseklik)) { header.removeClass('slideUp'); } aktifYukseklik = currentScrollTop; }); }); $(window).scroll(function(){ if ($(this).scrollTop() > 50) { $('#xenF-header').addClass('headerShadow'); } else { $('#xenF-header').removeClass('headerShadow'); } });
