Hello taikor-taikor and sifu-sifu,
I'm kinda new to this, so please bear with me on the problem description. I'm currently using a Tial 38mm wastegate with 0.7 bar spring installed. Running on a TD05-18G 4G63T with an electronic boost controller. So my questions are:
- If I'm using 0.7 bar spring, the wastegate should only open when the boost hits 0.7 bar, am I correct?
- I noticed that the wastegate will work normally (open at 0.7 bar) when I switch on the electronic boost controller. When I off the electronic boost controller, the wastegate will open at 0.4-0.5 bar range, so it that normal?
I hope those are not a stupid question, try to seek for answers. Thanks again and don't flame me if I describe the thing incorrectly.
but i've notice the ori mitsu meters were more responsive and reading smoother compared to those "aftermaket brand" then i realize at the back of the meters were steel connectors.:hmmmm: i assume the pressure reading were more accurate..i think la!
