hola soy de Puerto Rico I am interested in the console entiendolo of RM80 would not know how much is in dollars AMERICOM and whether it is the same for the car
it is pnp into AE101 center console if u swapped the engine with full wiring..
if u're using the original dashboard wiring, u cant use this, coz this is fully electrical instead of mechanical..
While traveling at 140km/ph, car was under power n was vibrating . Its like 'semput' when pressing the pedal. Slow down was fine ,press the pedal /floored to max ,rpm doesn't goes high . Could this cause by steeper...
'(00): This is one loaded Altezza. Packed with a parts list even Taniguchi would be proud to drift with. Firstly, based on a 1JZ conversion, it's then treated to a 2JZ block, and then fully balanced with parts like...
umm, im not sure if here is the right place, but i need some help here
recently i was trying to use the plug no.6, previously was using plu no.5. on the 1st day after i install it works like normal like that, no...
