Any auto transmition with turbo charge?
maoaltezza
dear all altezza friend,
any of u fix ur auto transmition altezza with turbo charge here?how much does it cost?where u fix that?:hmmmm:
plenty 1JZ auto altezzas ;6 at last count.
Auto 3S turbo dunno!!
best to follow the half cut-jzx100 4AT.
anyone tried the 5AT or 6 AT from IS250???(with JZX 100 engine and ECU)
If you wanna try supercharging, can check with Greytezza... :listen:
Bro coriolis...I would not advise anyone to go the supercharge way...becos it is too damn expensive. The only advantage is the torque kicks in very early and fast but the overall power is still limited unlike the turbo chargers.
Maoaltezza..if you are serious in turbo chargers, our stock AT gear box will have no problem with normal boost of 0.5-0.8. Any higher will mean shorten lifespan of yr auto gear box.
For Turbocharging, I will recommend you to see William of Trial Tuning...he will be able to advise you based on yr budget.
