Anyone used HKS PFC F-Con?
TRD.AE92
Hi,
1. Did someone here have it diagram?
2. Can PFC Fcon from 1JZ use on our 4AGZE? If yes, how to converting the harness from 1JZ to 4AGZE?
3. Compatible with AFM?
4. How the result?
I have not use but i have a friend who used it before,here's what i think,
1.It is engine specific,the mapping inside is for certain engine and not advisable to be used with another type of engine.
2.Since it is engine specific,it is compatible to the engine it is set up for.
3.Result of course better than stock,this is a piggyback not standalone,cause it is plugged between the ecu and sensor (from the looks of it),normally PFC F-con is coupled with HKS GCC to tune the air fuel ratio,like SAFC.
I would suggest u use e-manage instead.
Ermm.... how about the Fcon is for 4AGTE type, from AE86 turbo? I found it too... :listen:
Anyway... Between the emanage and SAFC and the PFC F-Con... which 1 better (I mean use on 4AGZE)?
PFC F-Con must use with GCC, otherwise no function, better use SAFC or E-Manage (latest technology)..
Yes... it had the GCC 2, and even got IPM, FCD, SLD, and FCC too...
How about the F-Con V? Got installer and tuner?
