Brembo brake different ?
cmng
Just like to check any different between the Evo 5-9 Brembo caliper and rotor ?
for front brembo
your help is much appreciated
yes, MirageAsti is right..
But its only the piston is slightly bigger,
the body of caliper & rotor still remain the same..
ok.. great
from my survey i checked rotor is same for all generation
but for caliper i not sure
in this case you all mention caliper wise , mounting all same between E5-9 except the E7-9 piston is bigger than E5-6
overall i can assume a E5-6 caliper can bolt on to E7-9 as well
the different is come from piston which translate the Piston Service Kit is different due to piston
am i right ?
TQVM in advance
kampoon
plan to fit on silvia
it hard to source those nissan brembo
kampoon
Of cause the latest one is better, i think it might have some minor improvement on each version, but for your case, just get E 4, 5, 6 will do.....for cost saving and easier to source ......happy modding
