KAZUTO GARAGE RCA - Roll Center Adapters/Adjusters
32mm negative roll center adaptor for AE86 - RM350
32mm super negative roll center adaptor - RM 420
32mm negative roll center adaptor for KE70 - RM350
32mm negative roll center adapter for JZX 81 - RM570
32mm roll center adapter for JZX 81,suitable for road use - RM480
*Roll Center adapter
The RCA blocks (roll center adapter) do a couple of things. First they move the roll center of the front control arms closer to the stock location after you lower your car. This helps your corner entry as the weight transfer is better ballenced. Second is bump steer, after you lower your car, the amount of angle on the lower arms and tie rods affect how much change in toe you recive as the car goes threw its suspension travel. You may notice it as you go threw a corner and hit a bump, the wheel will jump or jerk. By putting the angles back to stock, it lessen the amount of toe change you recive which will give you a smoother wheel.
*Negative roll center adapter
The NCRCA's work the same as rca's (correct for bump steer, move roll center closer to stock) but add some width to the track of the lower control arms by moving the bottom of the struts outwards. By doing this, they also add camber. On Battle Version NCRCA's, if you notice there are 2 levels of adjustment, The first level is 20mm wider and the second level is 40mm wider. I suggest going with the first level of adjustment to start with.
they do widen the front track of your car, pay close attention to clearances you have in your fenders, You usually have to remove the fender liner and or clearance the fender well and fender gap. Sometimes pulling the castor rods forward 2 complete turns will also help give a little added space. + n!
this roll center adaptor is made by 32mm thickness Aluminium Alloy 6061 by our Kazuto Garage R&D department.
**Aluminium alloy 6061 is one of the most extensively used of the 6000 series aluminium alloys. It is a versatile heat treatable extruded alloy with medium to high strength capabilities.
Composition
Table 1. Typical composition of aluminium alloy 6061
Typical properties of aluminium alloy 6061 include:
· Medium to high strength
· Good toughness
· Good surface finish
· Excellent corrosion resistance to atmospheric conditions
· Good corrosion resistance to sea water
· Can be anodized
· Good weldability and brazability
· Good workability
This has happened to be before a couple of times: My altezza suddenly loses power. No matter how hard i step on the accelerator, the pick up is really slow. This will go on for about 15-30 mins, and then the power is...
Here is some my collection on 30th Aug merdeka count down moment.
We have a cherish and treasure night.... Sir Teng, Madam Teng Eva ,Brain, Steven, Austin, Carmen, Eric and Wife, Ivan,Sir Michael, Madam Michael And...
