i think at the end of the day, you really have to put alot of thought into whatever mod that you're planning to do ESPECIALLY the irreversible ones as once you're in you have to follow through all the way. coz certain mods once you've done it its no going back (and even if you can go back also i won't be the same as before). i have also chose the struts, bars and braces way like normality. so far has worked fine for me (albeit the slight weight penalty) and it was a cost effective solution. and if anything also i can just remove everything if need be. just mafan abit![]()
